I went for the Titan Fenrir Evo in the end and fitted it today.
All seems to be running ok, back to 3 cores at the moment and showing around 25C idle in CoreTemp.
HWMonitor showing cores as around 25C and CPU 33C
 but the temp readings im getting are the roughly the same I roughly get same temps as you as I get around 26c while im idle & up to 40ish while gaming. - using HW Monitor
Iv got the same CPU & cooler as you have an got mine running at 3.3ghz on stock settings, but mine dont unlock to 4 coresbut the temp readings im getting are the roughly the same I roughly get same temps as you as I get around 26c while im idle & up to 40ish while gaming. - using HW Monitor
So I think the readings you are getting are fine.
Thanks, good to know my temps seem okay.
I see your running yours at 3.3Ghz, could you tell me how did you did this, was it just by upping the miltiplier or changing the vcore aswell?
Iv got no idea why it worked for me & not you...Im as new to overclocking as you are lol.....Are you trying x16.5 with 3 cores or 4th core enabled?
The max vcore is 1.5v. You might need a little bit more volts. Sounds liek you also have a geniune faulty 4th core, so keep that locked. Just try get the best overclock for your CPU for now.
