My lime green was in relation to the load of bull about the screen. If Samsung make it like we are told at the very least it will have the screen of the gs2. But I suspect it will be better
same here, i can't believe for a second they would take a back step now.
It wouldn't surprise me, unfortunately. If the costs of the new panels are too high then Samsung will have to hold off using them for a while.
Or perhaps Google are having a say in the price and want cheaper panels used?
The Nexus Prime solves these common misconceptions/complaints by adding a 720p screen, metal body and stock android.
Metal body, chance would be a fine thing.
Anyway, the screen is curved just like the Nexus S screen. The device itself will be very thin - 8.8mm - and have a metal chassis, unlike previous models.
I also think that the screen shouldn't be knocked if it is a Pentile screen - At 720p res it will still be very very sharp and the pentile effect maybe quite hard to see.
You will still get the advantage of more space on the desktop/screen/web page etc.
Having used one for 18 months I would never, ever go back to one. I really despise the way thay mess up 1 pixel lines and text, and make loads of shades of grey look very pink.
