Ill have to whack the gpu's back to 750mhz and see how it go's, theyll do it on stock volts which is handy.Think I will copy you although my gtx470's are still overclocked![]()
its got hella input lag unlike the alpha.
cause it's depressing![]()
Yep, noticed quite a difference by applying 4xmsaa (screenshot above) compared to a previous round.For anyone wondering about the graphics, some of the options don't get applied till the level restarts, so graphics comparisons are pretty akward currently.
Oh my days.
EA Releasing Caspian Border 64 man tomorrow!
Anyone have issues going full screen? ALT + Enter and the option in video settings isn't working.
I'm also getting a freeze and sound loop after every 10-15 mins of play, which means I need to reset my machine.
Had less problems with the Alpha than this FFS!!
How is the rig in my sig going to cope?
