My new 2500K @ 5.0ghz
20 Dec 2006
Hi all I was doing a late night ocing session with my new hardware and got to 5.0ghz but it needs 1.5v core and don't know if it's fully stable yet as have only done five mins each on Prime 95 and OCCT.
I know there's a sticky thread stating 1.35 is a safe upper limit but found this doesn't reallly get me anywhere.
I'm on a watercooled loop and temps max at 71-72 degrees.
Thoughts?
19 Apr 2003
Thoughts?
Personally, i would reduce your clock by ~400MHz and focus on getting it stable with reasonable voltages (under 1.4v) and then build your clock up incrementally from there (if you feel you need more than 4.6GHz).
OP
20 Dec 2006
I think I am at least 4.5ghz stable at 1.425V
I was just wondering if any more data of 1.5v core was available in terms of degradation/fried CPU's.
You see some people rocking these volts...
OP
20 Dec 2006
The 1.425 was from an Asus ocing guide on another forum. It was a suggested starting point I guess. Overall my chip probably isn't 'the best'.
Gonna see if 1.49v @5ghz is stable
7 Nov 2002
pantyhose factory
I thought 1.3x was the max vcore before you started frying ? unless you are using WC then i guess the temps would be ok as I assume max safe voltage is based on how much heat is generated and how fast your cooling can dissipate the heat before stuff starts to melt ?
6 Feb 2010
Unless you are playing on CPU demanding games that don't use all four cores (i.e. WOW, Total War series), then there's not much point clocking your CPU that high and shortening its lifespan, especially when it won't really give you any extra performance in games with you only got a single overclocked GTX470.
In most games, the frame rate for your GTX470 would be the same may it be the 2500K at 4.0GHz or at 5.0GHz...so why risk killing your CPU?
13 Jan 2004
Nope.
Temps are an element of longevity but that's not to say you can pump 3volts through a chip and keep it at a suitable temperature and it not go pop :p
OP
20 Dec 2006
Interestingly the 2500K at 5ghz draws about 20 watts less in-game than the Q6700 @ 3.9ghz did.
450W and 470W respectively
What is really interesting is at desktop before the Q6700 setup drew 270 watts!
This sandy build is 170 watts!
That's an entire lightbulb right there!
Yes I realise temps aren't everything when pushing more volts through, but I want to use my watercooling gear to its potential.
I also realise that 4.5-5ghz with my GPU there is nothing in it and I should be sensible...
It's just nice number I've reached, it was a target of mine too and wondered if the chips are ok at these stress levels.
It seems game-stable atm at BIOS 1.49v (just completed spacemarine which DID BSOD yesterday when it was unstable),
withCPUz saying a droop down to 1.47 during 100% load
I'll try 1.485v in bios next
edit 1.485v failed prime 95 after four iterations
13 Jan 2004
5GHz at those volts is not a 24/7 clock to be fair.
Aim for the best clock you can get at 1.35 and be happy knowing your WC is making the best of the heat generated.
I get the need to go more, mines at 4.5GHz and I want more but actually have no reason for it :D
OP
20 Dec 2006
Yeh I'll see how low I can get the volts back on 4.5ghz
It does seem quite stable at 5ghz with 1.49 atm
Gratuitous shot of the new gear in situ:D:
night shot:
30 Mar 2011
That looks awesome, going to read your buildlog now.
I have my 2500k at 4.5 Ghz prime stable at 1.34 Volts, As that is the highest threshold most guides tell you to go to Im happy with 4.5 Ghz. Never noticed any lag so wont push it further.
2 Dec 2005
Herts
I was curious about how much power these chips might be using at these OCs. The following assumes 3.3 GHz at 1.17 volts has a TDP of 95W (which is a worst case scenario remember).
4.5 GHz at 1.34 (as in Robertnpmk) is a 36% clock speed increase for a 79% power increase (169.9W).
5 GHz at 1.49 (as 3t3P) is a 52% clock speed increase for a 146% power increase (233.4W). 3t3P did you measure 170W at the wall under load at this clock?
Diminishing returns definitely :)
OP
20 Dec 2006
Thanks guys, I love staring at my PC hehe
joeyjojo how do you work out the wattage increases? multiplying the OC amount by the 95W TDP?
The readings I gave are at the wall yeh
170W idle
450W load
So no one has really been happy with my 1.49v lol
I'll scale back to 4.5ghz like the whimp I am tonight....
