Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Watch ya don't fall through the floor :)
5770 with that spec is quite embarrasing, you should get a 6970 or something along those lines.
I know I am skint and I had my 5770 in a dual core e8200 2gb ram, but a guy from work moved away and sold me his rig with no gfx card so I dropped my card into it but wont be upgrading for a few months, maybe xmas time
Any one with such a lowely card as a 5770
also got 1055T (6core) @ 3.5ghz
8gb ddr3
hoping to play quite well at 1650 x 1050
on my gtx460 [about the same performance as a 5770] @ 1920x1080 with everything set tyo ultra and 4x aa i get 40-60fps
i also have a 1055t but mines stock.
your game should bve perfectly playable at 1650x1050 ;)
GTFO 5770 was one of the best cards around when the 1055t came out, i think the only better ati card was the 5850
Am I gonna be able to run this at medium or with some settings on high with my sytem? V modest by today's standards although I get decent enough performance with everything on high with BC2 MP (the only game I really play).
Having a v limited budget for upgrading, prob around £150 and will be playing at 1650x1080. Any recommendations/advice? Just itching to get playing tomorrow and then weeping when my machine begins to squeal!
what does not work? I have BF3 set up for different actions on all of my mouse buttons?
Well if you would be do kind as to talk me through it I would be most appreciative.
I have tried:
Just plain using the buttons in the control section and it shows "unknown value" or something like that, and doesn't work
Using the assigned button as a "macro" in the razor software I.e. Button 5 = "c" for crouch (as key binds) and it doesn't work - despite the button press showing as a "c" in Word
Using the assigned button as a "key press" in the razor software I.e. Button 5 = "c" for crouch (as key binds) and it doesn't work - despite the button press showing as a "c" in Word
I even have issues with assigning more than 2 key binds, I select an action, click to assign - first two work fine - any more the xvreen just "locks" and I have to hit escape to go back a step on the option memu and no key is assigned
I'm using a razer Lachesis with the 1.10 drivers and 1.95 Firmware (checked and updated as the latest version)
If anyone that has managed to assign mouse buttons successfully can give me some suggestions they would be most welcome
Cheers
TB
Yeah, when it came out, not anymore.
yea and they are probably still perfectly fine for most games which is why some people still have them :P
im sticking with my 460GTX until i really need to upgrade it rather than fooling myself into thinking i need the best gfx card around to run games.
its not that i cant afford one either i just spent £350 on an RC car last month :D
Status
