Can a 6870/2500k handle high + some AA?
Installed the ATI Beta drivers thinking it would fix he stuttering but nope. Is it because my 5850s only have 1GB VRAM?
So I'm running a GTX 260 768MB. Have I seriously got abolsutley no hope of running BF3 with a playable frame rate?![]()
its genuinley moronic what they have done with caspian border servers, why not just open up more... whats the point in password protecting them and then making it so none of the passwords even work...
where the hell are you meant to even find the updated password ? all this does is **** people off
Yup
when vram requirement exceeds 1GB as in the case of my 5850, the fps drop to mainly around 22-23 fps and even dipping to 7-10 fps under heavy action
When vram is around 990MB, I get 38-60 fps on high-ultra for 1920x1080p
ofcourse I had to turn AA off and shadow low.
1GB Vram limitation is definitely holding this card potential
Overclock it, you can run all on medium AA/BLUR off/SSAO OFF with playable frame rates in metro.
Caspian though, give up![]()
My brother with gtx260 can play on medium settings at 1680x1050 res in caspian border
What should I do? Lower the resolution from 1060 * 1050 and lower AA to 2?
What is his system?, I'm playing 1920x1200
Reckon my 5870 will be ok at high settings 1920x1200?
Seems pretty pointless playing if your not sniper on this map imo
