Is BD performing worse in games?
We don't know yet, that's the thing.
You get so much conflictual talk regarding CPU's and games.
Having gone from a hex @ 4.375GHZ to my 2500k, my frames are a lot more consistent, and this has been stated by a lot of people who've done similar stuff from Phenom II to SB.
If BD is around the same IPC performance, (ignoring OC's for now) then it's going to be the same as usual for games, but only if you were to compare the FX4100 with a Phenom II X4, as the 8150 will get a massive turbo boost.
Not really, it proves that throwing cores isn't a solution to lower IPC.Similar here but in my case it was a 1055T at 3.8 to a 2500k at 4.6 so I guess it's not too shocking.
Not in today's world no but once developers develop engines that are designed to run on multiple threads (i.e. X: Rebirth) then we may see good bumps in performance from either team.
There aren't many games out just now that use more cores/threads.
EDIT : Sounds like a very solid piece of evidenceIt seems the Passmark scores for the Core i7 2600K were for overclocked CPUs.
Here is a comparison with a Core i7 2600K at stock speeds:
http://www.overclock.net/15137769-post6861.html
This post mentioned Bulldozer will have a reasonable IPC increase:
http://semiaccurate.com/forums/showpost.php?p=136387&postcount=2208
All @ 3.6GHz
All have 570GTXs and....AMD FX loses both in 2d graphics and 3d graphics
i7 950 has hyper-threading turned off
Also, all of them have 4GB and again AMD FX loses(in mem test)
EDIT : Sounds like a very solid piece of evidence, I hope it's true, but I can't see it.
And, you didn't read did you?
Yes I did read the whole thread.
The same chap who post the chart mentioned something else:
http://www.overclock.net/amd-cpus/791495-bulldozer-blog-live-687.html#post15138181
"Originally Posted by flashtest:
If they pass i5, in rendering/gaming (3d studio specially) i have two less motherboards to sale and two bulldozers to preorder "
"Seronx:It does"
3D Graphics test then extrapolating 1024x768x32 to 1920x1080x32
I didn't intend to do that.My point was that 4.6ghz vs 3.8ghz wasn't a fair comparison.
IPC is of course part of the issue but the main reason that quad core isn't suffering compared to hex core is that apps aren't making use of the extra cores.
The way things currently work you're of course right. Sadly, this isn't likely to change in the near future either.
Turning my comment into something other than what it was is a bit tiresome though.
Likely fake, or used to hype it up, same as with any launch (lol).Guys if you google, an extensive list of benchmarks and performance conclusions have come out for the bulldozer
Have AMD issued an actual (official) release date for Bulldozer?
Asia.There's a Youtube video where they confirm October for some region or another
