AMD Bulldozer Finally!
Is BD performing worse in games?
We don't know yet, that's the thing.
You get so much conflictual talk regarding CPU's and games.
Having gone from a hex @ 4.375GHZ to my 2500k, my frames are a lot more consistent, and this has been stated by a lot of people who've done similar stuff from Phenom II to SB.
If BD is around the same IPC performance, (ignoring OC's for now) then it's going to be the same as usual for games, but only if you were to compare the FX4100 with a Phenom II X4, as the 8150 will get a massive turbo boost.
Similar here but in my case it was a 1055T at 3.8 to a 2500k at 4.6 so I guess it's not too shocking.
Not in today's world no but once developers develop engines that are designed to run on multiple threads (i.e. X: Rebirth) then we may see good bumps in performance from either team.
There aren't many games out just now that use more cores/threads.
And I've said previously that BD's modular design, with the ability to "Add cores easily" means that in the future, it'll be very good. Right now? Not so much.
The 8170 is out in January.
The ones before that are out in October.
8150 is performance wise an Intel 990X or something. According to the benchmarks.
The rest is nigh on par with an i7 2600k
I just hope prices will come down for the i7 as that is what i will be going for.
Always found Intel to be more stable than AMD in the long run.
It seems the Passmark scores for the Core i7 2600K were for overclocked CPUs.
Here is a comparison with a Core i7 2600K at stock speeds:
http://www.overclock.net/15137769-post6861.html
This post mentioned Bulldozer will have a reasonable IPC increase:
http://semiaccurate.com/forums/showpost.php?p=136387&postcount=2208
EDIT : Sounds like a very solid piece of evidence :p, I hope it's true, but I can't see it.
And, you didn't read did you?
All @ 3.6GHz
All have 570GTXs and....AMD FX loses both in 2d graphics and 3d graphics
i7 950 has hyper-threading turned off
Also, all of them have 4GB and again AMD FX loses(in mem test)
Yes I did read the whole thread.
The same chap who post the chart mentioned something else:
http://www.overclock.net/amd-cpus/791495-bulldozer-blog-live-687.html#post15138181
"Originally Posted by flashtest:
If they pass i5, in rendering/gaming (3d studio specially) i have two less motherboards to sale and two bulldozers to preorder "
"Seronx:It does"
"Seronx:It does"
This is his evidence
3D Graphics test then extrapolating 1024x768x32 to 1920x1080x32
Ergo, pointless crap, we may's well wait for real benchmarks, we don't all sit around playing pass mark. I want to see how it compares to current AMD CPU's with multi-gpu configurations etc.
Not really, it proves that throwing cores isn't a solution to lower IPC.
My point was that 4.6ghz vs 3.8ghz wasn't a fair comparison.
IPC is of course part of the issue but the main reason that quad core isn't suffering compared to hex core is that apps aren't making use of the extra cores.
The way things currently work you're of course right. Sadly, this isn't likely to change in the near future either.
Turning my comment into something other than what it was is a bit tiresome though.
I didn't intend to do that.
Of course your 2500k's at a higher clock, ergo better etc.
But, AMD have went the "Add more cores way", if you're noticing gains with less core, albeit a higher clock, then it doesn't bode well for adding more cores at present.
Although it's not an exact science.
4 x 4.6 = 18.4
6 x 3.8 = 22.8
With less theoretical processing power, you see gains, clocks and cores don't amount to much if the IPC isn't there, that's what I'm getting at. You're going to argue, even though you know it's right :p.
A. I doubt the benchmarks are faked. Check them out.
B. Bulldozer is being shipped due for release between Oct 12-24
c. 8150 Available for launch.
D. 8170 - Release date Q1 2012
