He’s got one of the IN-8-2 kits with tubes included back in stock if anyone’s interested. Click here. Tefal?![]()
i've only got £50 quid to last till payday![]()
), i never managed to make one thing that even came close to working
) but not a lot of it is actually required for the course.
Oh, and all in favour of changing thread name to "***Official Electronics Thread***"?![]()
Ha, i remember pre-GCSE Electronics (i couldn't take DT at GCSE), i never managed to make one thing that even came close to working
.....wait a second that sounds far dirtier than I expected
Sounds good to meOh, and all in favour of changing thread name to "***Official Electronics Thread***"?![]()
definitely this
the fume extractors don't work at all the peak from the bump caps just holds the fumes in your face
Anyhow payday is next Friday so I'll be finally buy some electronics stuff to start playing with myself.....wait a second that sounds far dirtier than I expected
So I've got in mind some early projects (lots of practice soldering too)
Turning an old 250W pc PSU into a bench supply with fixed out puts + a variable one.
a little hand held fume extractor from an old pc fan + little tin (more to just get used to makign things small/compact + it's relatively practice
uv exposure box + an etching bubble tank.
then using that to make an arduino single sided serial
Also need to make a serial adapter to use to program it >.<
Would fancy around Christmas time to be looking to build an 8*8 LED cube
Any other fun/good learning pieces you guys can think of?
also tips on what to buy/where from etc :
mostly been looking at rapid and ebay.
Thinking antex xs25 or is there a better one that's not insanely expensive?
also tips on what to buy/where from/any things you've found really useful lthat i mgiht over look.
Feel like taking mine apart and finding the fault?
It looks really good though taliesyn![]()
I think i'll take AODs advice when i can be bothered to go and put money in the bank and get a Solderpro 50 butane soldering iron, just over £20 for the full kit at Rapid i think. I tend to get as much stuff at Rapid as i can, saves on delivery costs![]()
Personally I wouldn't use a gas soldering iron for pcb work, although I have an Iroda one that is fantastic for car wiring and that sort of thing. The one I have seems to get too hot for delicate stuff, but maybe that's just me. The Antex you're suggesting is a good iron. I have a CS18 that I've had for years, and it's still going strong![]()
Gas =/= far hotter, surely? The Solderpro 50 is roughly equivalent to a 30-70W electrical iron, is it not? I can't see how that would be too hot, the figures say in the lowest setting the tip will be about 250C.
IN-8-2 kits with tubes back in stock again. *clicky*
apart from maybe a PCB drill press... i'm sure there's a way of making one of those relatively cheaply)
Thanks
Tefal, if you're using an ATX supply as a bench PSU be careful as they can output insane currents, particularly on the +12V rail, that will happily destroy any electronics project you attach to it if there is a short.
And it's big
This gives an idea how big it really is
:D :D :D[/font][/QUOTE]
Or how small the orignal ones are. :D Are you now building another large one?
Permabanned you need to go make an official ***************** electronics thread![]()
) or someone should do it
Cs18's are what we use in college, and nicely because we're in aero industry we still use lead solder and don't have to dick around with the lead free stuff unlike every other industry group![]()
