Yeah but on top of that, playing emulators/games on the HDTV with a wiimote or six axis controller, being able to browse my LAN directly from a file manager app, manage files to and from the phone with other computers on the LAN, turn my phone into an FTP server, turn my phone into a managed access point and so on. Controlling how the web browser is seen by websites, using different keyboards and so on and so forth.
Also here's the battery life on Modaco's GR5 ROM with the extended battery. This is the first full charge I have given it since Friday and I have used it for virtually everything. Modaco ROMs also suck more juice than any other ROM, I notice the Android OS bug is not fixed in GR5 regardless of what kernel I use.
I will try another ROM soon enough but so far I have gotten better battery life even on this ROM than with the stock battery given how I use the phone. Will be very interested in seeing how it fares then.
{pics removed}
Ignore the little charge at the bottom, that was last night when I plugged it into the PC to run the Monday evening backup, USB doesn't charge it very fast anyway so would not skew the above results at all.
There are no ROM's that allow you to do that. AOSP bluetooth stack is needed for PS3/Wiimote, Samsung based ROM is needed for HDMI.
, cba buying a new controller
.who uses cm7? video camera isnt working at all now on n73 for me.
I've got n72 and camera seems fine at the moment. Love the speed of it. Some other features annoy me though.
If I have a slightly older version of CWM will it update it to 4.0.1.5?*n00b question alert*
I'm running Litening 6.1 but fancy changing to Batista ROM - when I flashed Litening via Odin it roots the phone + includes CWM. I presume to install Batista I just download it, put it on the SD card and then boot into CWM and flash?
The confusing part (for me) is that in the Batista features list it says it includes CWM 4.0.1.5 - how does it include CWM when you need CWM already on the phone to install the ROM?If I have a slightly older version of CWM will it update it to 4.0.1.5?
Exactly how you've said it![]()
Your phone is now rooted & CWM included from Litening rom.
Stick Batista rom on the SD, boot into CWM (reboot phone & hold vol up/home/power together). wipe cache & wipe davilk (under advanced in CWM)
Install from ZIP & then choose zip from sd. CWM will update if it is an older version.
Make a back up too in CWM incase anything does go wrong (I can't stress this enough!)
yeah camera is fine for me, but when I slide over to video it freezes. Can you test please?
