I have a question to OP. I've been eyeing this thread for awhile, and while I know you mentioned that there is only 55mm of room, 25 for the fans, and 30 for the radiator, how exact is this? The Magicool 360 Elegant Radiator is 34mm thick, any chance that there is 4 mm of extra room in there?
thanks! I'm looking forward to your progress!
It's 26mm thick
. This is the Magicool Slim, not the elegant. You can fit a thicker rad if you won't mind cutting your ATX power connector a bit (the plastic bit will need sanding down), and if your motherboard doesn't have any big protruding heatsinks in that area.
