- 7 Jul 2009
- Newcastle/Aberdeen
No, that's not too hot at all. The tip temperature for the 60/40 Multicore solder I use should be around 300C, so it's slightly low if anything. I have the Solderpro 70, and I just can't seem to get on with it for detail work. Like I said it's probably me, I'm probably setting it too high.
Mind you I would suggest that 70W is far too high for PCB work, and an 18w or a 25w iron is much safer.
I'll stick to my solder station. Cheaper than wrecking boards![]()
Well at the highest setting it's 500C, so quite good i reckon
For doing precision work it isn't a matter of if it's electric or gas, for me at least. It's a case of how thick the iron is and how close to the tip you can hold it, as well as anything else that might get in the way (wires). The 50 model looks a lot better in these areas than pretty much everything else in the price range. Plus you can use it for more than just soldering
The Weller WLC100 for ~£30 looks okay, but i think it would be too bulky for me to get on with. Something like the Metcal MX500 would be absolutely perfect, but it's out of my price range by a long shot.
