I have [email protected] and it seems to be fine even at 1920x1080p res.
You need to overclock you Q6600 more. The other problem is the vram issue with caspian border.
I also have 1GB 5850, but usually run out of vram at that res. This results me in getting 20 something fps and even dip to 7 fps lol.
Disable some settings such as AA and shadow to low and see if that makes any difference.
Edit: Did you install amd catalyst 11.10, which is designed for bf3 beta?
Anyone doing a lot of flying on Caspian? After a while my graphics get corrupted. Loads of triangles pointing towards the ground from where I am aiming. 560Ti on the beta drivers. Seen the same thing on Metro in the alpha.
Caspian is unplayable on my system as an infantry, however in the jet and or helicopter it's playable![]()
Few cb shots i took, quite impressed with how my system handles it.
snip
I was considering switching to a single gtx 580, (then add another later down the line). Decided id be better with what i have and wait for new cards.
Must be something to do with amd cards id hazard. Im running on high, 2x msaa, 16xaf, motion blur on, ambient occlusion off.How come your MSI Afterburner recognises two lots of VRAM? I have crossfire 5850s but it only sees one of the 5850s VRAM. Also what settings are you playing it at?
You getting something like this? http://i.imgur.com/xgPNX.jpg
I'm on a Q6600 @ 2.8GHz with a 5850 1GB, 4GB ram. Metro was fine, but Caspian brings my pc to its knees. I use 1680x1050 Res. I have tried Low, Med, High and Ultra settings and the difference between High and Low, in FPS terms is negligible if any.
FPS ranges from 20 to 40 typically, which "feels" pretty low in this game. It's not really very playable when compared with the perfromance I get in BC2. FPS in the areas where you want it to be high, around the centre of the map, drop quite considerably, especially during firefights.
I may as well play at high because the difference in FPS between that and low is almost nothing. As such, I have come to the rather disappointing realisation that the Q6600 just cant hack BF3. Those kind of results suggest that the CPU cant keep up.
Not really complaining though as Ive been meaning to upgrade anyway, just not quite so soon.........
I think I'm done with this game, I've played all PC Battlefield games from the beginning but it's more BC3 than BF3.
Going to cancel my pre-order tomorrow ...
What a ****** pity, not been this disappointed in a game since the Warhammer mmo
