!!**Official RAGE Thread**!!
Why does mine look so bad?
My config
Code:
seta com_allowConsole "1"
seta com_videoRam "1536" //sets the Video Card memory Set this to the amount you have in MB
seta com_maxfps "120" //limits the frames to 60 can be changed to what you desire
seta image_anisotropy "16" //Using the highest setting here but you can set as 2, 4 or 8
seta image_usecompression 0
seta image_filter "GL_LINEAR, GL_LINEAR_MIPMAP_LINEAR" //filtering for light maps
seta image_preload "1" //Use preload images when ever possible
seta image_lodbias "-1" //LoD settings
seta image_ignoreHighQuality "0" //Sets up for using HQ gfx
seta image_ignoreLowQuality "1" //ignores the low textures
seta image_useCache "1" //Enabled Cache to allow the textures to load properly without popping
seta image_cacheMegs "1024" //Cache size in Megabytes
seta image_cacheMinK "10" //Cache minimum size in kilobytes
seta r_aspectRatio "1"  // 0=4:3, 1=16:9, 2=16:10, 3=5:4 TFT, -1 custom
seta r_fullscreen "1"
//seta r_customAspectRatioV "9"
//seta r_customAspectRatioH "16"
seta r_swapInterval 1 //VSYNC 1 enabled, 0 diabled
seta r_useHighQualityPostProcess "1" //Fore High Quality post proccessing
seta r_shadowsHighQuality "1" //Fore High Quality shadows
seta r_displayRefresh "0" //keep it so the engine doesn't double render a frame
seta r_renderer "best" //highest rendering options
seta r_multiSamples "32" //Set this to 16 or 8 if you're having low-fps as 32 is the Max Multi-sampling
seta r_useHBAO "1" //Ambient occlusion
seta r_useRenderThread "1" // 0 Disable or 1 Enable threaded rendering  useful for newer cards to increase performance.
seta r_visDistMult "1"
seta r_useMotionBlur "1" //use blur
seta r_skipBump "0"
seta r_skipSpecular "0"
seta r_skipNewAmbient "0"
seta r_shadows "1"
seta r_cgFragmentProfile "best"
seta r_cgVertexProfile "best"
seta vt_lodBias "-1" //LoD settings
//below is cache settings And advanced GFX settings
seta vt_pageimagesizeuniquediffuseonly2 "8192"
seta vt_pageimagesizeuniquediffuseonly "8192"
seta vt_pageimagesizeunique "8192"
seta vt_pageimagesizevmtr "8192"
seta vt_maxPPF 64 //Set this to 64 for Quad-cores CPU's or higher, 16 or 8 for dual-cores CPU's
seta vt_preload "1"
//Begin Advanced GFX Filtering and Sharper Images. Comment these 3 lines out if you are having issues or don't like the way it looks.
//seta vt_filter "GL_NEAREST, GL_NEAREST_MIPMAP_LINEAR"
seta vt_envf "GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_MODULATE"
seta vt_blend "GL_NEAREST, GL_NEAREST_MIPMAP_LINEAR"
//End of Advanced GFX Filtering
seta vt_useCache "1"
seta vt_cacheMegs "1024"
seta vt_cacheMinK "10"
seta vt_ignoreHighQuality "0"
seta vt_ignoreLowQuality "1"
seta vt_maxaniso 4 //Set this to 0 if your having lots screen tarring issues and do NOT set this higher then 4 otherwise it will corrupt the Mega-Textures
seta r_sb_frustomFOV "92"
seta vt_minlod "-1"
seta vt_uncompressedVmtr "1"
seta vt_vmtrcompression "none"
seta vt_qualityDCTChroma "100"
seta vt_qualityDCTLuma "100"
seta vt_qualityDCTNormal "100"
seta vt_qualityDCTPower "100"
seta vt_qualityDCTSpecular "100"
seta vt_qualityHDPLossless "1"
seta vt_qualityHDPDiffuse "0"
seta vt_qualityHDPNormal "0"
seta vt_qualityHDPPower "0"
seta vt_qualityHDPSpecular "0"
What it looks like at the start of the game, it looks so blurry!
How does it fare on the consoles? do they have any of the problems we are having?
I mean it's obvious we just got a straight port from the looks of things but from the sheer amount of bugs/glitches ect it's as if it was ported and never tested.
Stuff like this goes a long way towards convincing me to avoid all pre-orders from now on. far too many games are released is a shoddy state lately.
Friend has PS3 version said whilst it does have texture popping he finds it very enjoyable he did try PC version also and said that in comparison PC is far far worse. His rig isnt super high but still more than capeable of playing new/high-end ish games.
I'm not going to play this until they patch it, I'm so disappointed. One of the reasons I buy for pc is the superior graphics.
So he is basically trying to use excuses and get out of the mess he has made? Whilst consols arent as powerfull they have many great looking games in there own right.
ALL devs have become lazy to the PC over recent years which is a shame but when a PC game is done right there extremly hard to beat
Is that config file actually working? coz for me it does nothing it seems to be ignoring rageconfig.cfg :(
It makes an ever so slight difference, the main thing I've noticed is that there is no tearing if I force vsync on in the cfg (global setting to app pref in nvidia panel).
If I try to change textures to 16k my game crashes when loading into the the level so I think some settings are doing something at least.
My frame rate is stuck at 60fps so the set limit in the cfg obviously does nothing either :(
Theres definately been some recycling from Doom 3 in this game. Anyone else noticed the combat shotgun uses the same reload animations? Same for the authority machingun, it even looks like a modified version of the machinegun in doom 3, the p90 wannabe. The rocket launcher again seems to be taken from doom 3 and shrunk slightly.
Well I have finally got my games working and the textures no longer pop up at the sides. Now I have played abit I can say it is a great shooter. It is the first time I have seen animations on the enemies where they actually react to every bullet that hits them. I have been wanting to see this for years.
Using a 5870 + 3.4ghz C2Q and the rage drivers, the game runs smooth at a near constant 60fps at 1920x1080 with 4xaa. I get slight fps drops when entering new areas, but on the whole performance seems very good and consistent, like most idsoftware titles in the past.
Unfortunately the game has clearly been released unfinished. The texture pop in is ridiculous and a much bigger problem than the blurry texture. I mean wtf were they using to test this game - a 12" vga crt? Either that, or they forgot that they were developing the game for a PC.
Also the vsync implementation is broke and I get ridiculous amounts of tearing, even though the fps counter reads 60fps. I also think it's absurd that we PC users now have to scavenge around the installation files to change basic graphics settings - it should be an extra avenue for configuration not the only one! From a long standing PC developer like id software, it's pretty damn disappointing.
As a result I'm going to hold off till they patch this. Yes, I know there are fixes/tweaks, but I feel it's not really my job to fix stuff I just bought new. I can tolerate certain bugs/glitches in games, but this has clearly crossed the line.
Such a shame, as the game clearly has some jaw dropping attention to detail in some areas.
to fix fov add to your launch options
default is 80 so the below options add to this.
+cvaradd g_fov 10 for 4:3
+cvaradd g_fov 20 for 16:9
