Does anyone know if the pagid break pads are the same as the renault oem ones, reason I ask is that they are fairly cheap on euro car parts and I have a sneaking suspicion they are as pagid make break pads for many different performance cars!
Gearing my car up for my mot, going to need the following:
2 x new front tyres hankook k115 ventus prime 2 £170 fitted
2 x new front break pad sets ~£30
Filter and 5L 5w40 fully synthetic oil ~ £40 (part of service anyway)
2 x front wipers ~ £15
1 x Washer motor, mine completly dead, will be a right beach to remove wipers! ~£13
1 x Number plate bulb (assume 12v cylindrical ones , can use from the ones i removed from sidelights)
Decided against winter tyres after all, was going to go for the kumho ones around £75 for 2 front but thought.. well if it does snow I wont be able to really drive anyway considering the car will act like a snowplough with only ~2inches clearance under the bumper!
Also my manager knows I live in the ****sticks so will hopefully give me a few days off without tapping into holiday if it does snow!
Very expensive month as I just spent 350 getting a collar tapped into the head to replace a dodgy spark plug that sheared and will also need a new door (which ive found) to be sprayed up arctic blue due to *ahem* complications while attempting a tow!
To top that off insurance is the same time as mot! my bill for this month has already taken octobers and novembers beer money!!
Does anyone know how much I should be looking at to get a door spray up if i do most of the prep work myself? might throw in the wing mirror covers while im at it seeing as they'll have the paint ready!
