AMD Bulldozer Finally!
who don't know if 7000 eats more bandwidth
7000 are PCI-E 3.0, something AMD doesn't have, and if AM3+ is given more life, won't have in 2012 either. That said, Intel won't have PCI-E 3.0 till Ivy hits, but it's still 1155.
SHUSH YOU!
How could you EVER understand the need for 120 USB 3.0 devices and 60 HDDs all needing THEIR OWN port. Jeez :mad:
Crazy.
But you can change to accommodate.
You could cut your hard drives so you run the same amount of storage in less drives using RAID or something.
My board has a lot of USB 3.0 etc and was 260 quid.
true but i prefer keep my data on separate disks so if one gets a problem the others will be still ok.
so ?
it still backward compatible to 2.0 , but my point was we don't know if 7000 eats more bandwidth from 2.0 16x so if it does then running it on a 2.0 8x would mean a higher performance hit than now..
understand now?
so ?
understand now?
But the PCI-E 3.0 at 2x would be the same bandwidth as a PCI-E 2.0 16X lane.
Rendering the point moot.
There wouldn't be any hit.
You missed the point.
You need to read up on the different RAID types :p
Drive mirroring with RAID 1 allows you to directly access the data if one of the two drives goes kaput. Other RAID levels with parity need at least three to four drives plus you need to rebuild the RAID eventually if one drive is faulty but data is still readable.
i didn't say anything about 3.0
gurusan said
Who gives a rats ass about dual 16x lanes? 8x 2.0 is plenty
but im saying if 7000 eats more bandwidth from 2.0 16x so if it does then running it on a 2.0 8x would mean a higher performance hit than now..
So as far as i can tell from the "Rumour Mill", There will be no Pre-order, Just a lifting of the NDA on wednesday 12th, then all the benchies from "Proper" reviewers with "Proper" bios's and drivers then a fight to buy from someone who has them in stock.
That about right?.
It should be no surprise that AMD won't be very competitive. Why?
  • The whole design screams out that it's not for the PC enthusiast. We still want 4 fast cores, not 8 average cores.
  • No, give me 8 average cores over 4 fast cores every day of the week.
Does this include PCS2x, a PS2 emulator?
Yes.
So they can sit around idle?
PCI-E 3.0 8X = PCI-E 2.0 16X, making your bandwidth argument moot. I don't see why you're missing that?
1155 might be 8x/8x, but it'll be PCIE 3.0 making it the same bandwidth.
My point exactly.
Yes, and I said that you missed the point of my post. You use a few percentage points performance hit as an argument but ignore the massive performance difference between the actual platforms.
My point exactly.
You do realise he was answering another poster talking about PCI-E 2.0 8X/8X and not PCI-E 3.0 8X. On top of this since Sandy Bridge has an on-die PCI-E controller it means you will need to wait until Ivy Bridge which is around six months away at least. Also, only a very few socket 1155 motherboards have PCI-E 3.0 ATM. Are they even available in the UK yet??
You're in the minority.
But if you'll be using 8 threads 24/7, you're right, 8 average cores all the way.
?? So maybe there are people who want to use loads of disks. You got to understand people have different needs for their computer than you. I myself have no need for more than 3 or 4 SATA devices so having a million SATA ports is not important for me.
u said before this PCI-E 3.0 2X = PCI-E 2.0 16X, now your saying PCI-E 3.0 8X = PCI-E 2.0 16X.
lets just wait and see tbh.
