- 25 Feb 2007
- Bedfordshire
Well I think it is time for a thread update. It has been a busy summer for the GT6. It has been out most weekend either at shows or for my driving enjoyment. I reckon I must have put about 750 miles on it over the last 4 months. I say reckon because the odometer is still broken. This is however on my list of things to fix over the coming winter months.
The highlight of the summer was taking the car to the Silverstone Classic. This event really was a lot of fun with so many classic cars in attendance. Camping was good fun however getting everything in the GT6 was a bit of a squeeze. None the less “Camp Triumph” was established and bacon was eaten for every meal
Both of the days I was at the event my car was on the front of the Triumph Sporting Six stand which was really cool:
The whole event was just excellent, from the racing to having a nose round the pits at 60's F1 cars. I really would recommend it as it is a brilliant weekend.
The GT6 also had its MOT last weekend. I was a little apprehensive about this as it has failed on the handbrake before. However it turned out that my fears were unfounded as it passed with flying colours with no advisories which I was quite chuffed about.
So, over the next couple of months I am going to be doing some work on the car fixing a couple of things up, doing some servicing and hopefully doing a bit of upgrading. The first thing on the list is to do a service on the car. This will include but not limited to changing the engine/gearbox/dif oil, change the coolant and change brake pads. I am also going to order a new speedo so the odometer can be fixed.
Over the summer months it was quite apparent that the car does not like the heat. It is fine while it is running along but as soon as you stop the temperature goes through the roof. If left idling for any amount of time it will start to overheat/stall which when in heavy traffic is not good. To rectify this I am going to be fitting a Kenlowe fan. As I think I mentioned before I am trying to keep this car as standard as possible however I think this upgrade is a necessary one as it will make the car much more usable and reliable in hot conditions.
One of the other things that I will have to fix is the new carb linkages that I made. They have somehow become loose around the roll pins. This is allowing the front and rear carbs to open differently. Not the end of the world but the car will run better once this is fixed.
I'll be updating this thread a bit more frequently over the next couple of months as I will be working on the car not driving it
. I'll finish this post with a couple of pics I have taken over the last couple of months:
