nandroid is installed when you root your phone - http://forum.xda-developers.com/showthread.php?t=1103399
Still no video cam for me on CM7.1 :/
thanks to the pushback of the samsung event prices of the SGS2 are now up £40.
So very unhappy.
I have a brand new one for Sale this or next week. Not sure how much i should list for £325?
TB has a free version, but to be honest i would buy it. well worth having and you use on future devices. Nadroid backup is like a imagie backup and you will gain access to that once rooted. have you rooted yet?
what do you mean?
Depends
Prices are see-sawing like mad atm. Once the prime comes out I think we will see sub £350 prices new.
Not rooted yet. I am going to fully read the details and maybe try it all tonight.
Will TB backup SMS messages as well? Does it backup everything to my PC (with a desktop piece of software) or to my micro sd card? The reason I ask is I have the 16GB SGS2 and 1 16gb card in it that is already half used, but no other micro sd cards.
rp2000
Screen goes black when I slide the slider to video mode. I suspect a full wipe would fix it but it's such a ballache.
what rom were u coming from? a full wipe is always needed from other roms, and i suspect if you came from a beta cm7 it would apply.
I've been using CM7 since nightly ~50 ish, I think at ~70 ish the vid cam issue started - the problem is well documented over at XDA but a lot of issues are being ignored with the pending release of ICS!
No need to wipe from beta to full cm7 as the full release is no different than the incremental beta releases.
Edit: Hang on, does full release mean that devs can now code a BLN kernal?
