AMD Bulldozer Finally!
Heres a fact for you. According to the benchmarks, In BF3 Beta, a GTX 580, with an AMD X4, pishes more frames, than an I5 2500k or a I7 2600k overclocked.
1.) It falls under the error of margin 2.) That's because it's a GPU bottleneck.
You could run that test multiple times and get a different winner out of the top ones every time.
Are you saying an SLi setup would make the Intel stand far out from the AMD benchmarks?
Relieving the GPU benchmark and requiring the CPU's to produce more frames, as long as the GPU's are pumping out more frames than the CPU's are capable of.
not in bf3 ;)
quite under whelmed at how a single 580 gtx does in bf3 tbh not worth 360 .00 for 55 fps
There's no law that says people have to run all their games maxed.
If a new engine was released today, that could only be run maxed in 10 years time, would all today's gfx cards be crap because they could only put out 3 FPS maxed?
Nope. You'd just scale back the settings for the next 10 years :p
yes but a 360.00 card which runs at 55 fps no thanks. might aswell keep same card i have until next gen .
only difference is you can run high or ultra at same res with same fps
The following chart was posted on XS.
It seems to be from this review site:
http://www.ozeros.com/2011/10/labs-¡amd-fx-en-ozeros/
It looks like the top three charts are for the FX CPUs.
The Core i7 charts which are blurred have a three in them?? :confused:
Too right. If im paying that much for a GPU, not only do i expect supreme frame rates, but it better wipe my..nose too!
Helpful :p
EDIT : AMD in my experience have always been good at 3DSMax rendering. my 965 at 4GHZ could outpace a 4GHZ Q9550 (I think, it was the same or something)
Is it the lower the better?
Martini is gonna be chewing on his words when the bulldozer outperforms his crappy I5 setup hahahahahahahahahahahah lollll :D im tuggin ya chain martini :D AMD have always been a bit better at rendering video and stuff
How you suppose we do that??
