mate i was the same for ages, asked on here 2 pages back and got those replies, i kinda felt "well know one told me"![]()
To be fair, no one told me either. I just went to settings and looked at storage and it told me there where it was.
I'm running my S2 on stock and using GO Launcher and I've disabled "auto-rotate" as I dont like my homescreens flipping but is there any way to make it so the internet browser does even when I've got it set like this?
Thanks......
I've just received my shiny new S2 today and whilst copying all of my photos and videos on to it via my laptop, I got a warning saying that my new device might not be able to read the files!?!?!
The pictures were all simple jpeg files off my last phone and they seem to play fine (and the videos) but for some reason the date on the photos have all been changed to todays date and time instead of retaining the date and time they were taken - so now I cant put them in date-taken order!
Anyone got any ideas on how to fix this???
Thanks guys....
change the auto-rotate on go launcher only - its in the go launcher operation settings
enable usb bugging and then just drag and drop files - I've never had the above issue.
Doesn't work via mobile data - I get "Sorry, comic data is temporarily unavailable." Works fine on WiFi.
EDIT: I'm on Vodafone as well.
works fine for me on talkmobile - try opening up your APN and pressing save, sometimes refreshes it.
The USB jig does remove the yellow triangle, afaik (I don't have one, don't see the point unless my phone needs returned) you just plug it in, turn on (into download mode) reset and it's done?
What firmware are you on? As it doesn't work with the new bootloader. XDA has the old bootloader that you can flash with Odin so that the jig works again.
Im on the latest Kies one which is 2.3.4 XWKI4
I guess the bootloader could be the problem.
Yep, you have the new bootloader, just download and flash the old bootloader from XDA and you'll be able to use the jig again.
Edit: From the XDA post here:
If you've already flashed a full package from elsewhere or updated using KIES and cannot reset your binary counter using the Jig just flash this package in the PDA or Bootloader section of Odin to replace the bootloaders and then you can reset the counter: http://www.multiupload.com/LQQBRQVJUD
