** NEW RANGE INCOMING - PRE ORDER DISCOUNTS FOR ALL ENERGENIE PRODUCTS **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Today we are proud to announce an entirely new range of products.
Now we all run high end systems and many of us have countless electrical devices that could benefit from these items.
We are stocking a range of energy saving devices that allow you to remotely turn off your devices, monitor power usage and manage your electricity usage.
For a limited period, we will be offering a special pre order discount. With stock due to land in the next few days, you are going to have to be quick to pick up the product at this special introductory pricing.
Energenie Power Meter @ £9.80 inc VAT
The Energy Saving Power Meter will measure the energy use (and calculate costs) of running household appliances. This helps you lower your power bill and reduce carbon emissions.
Ideal for keeping an eye on your system power consuption.
Technical Data
Voltage: 240V ac 50Hz
Maximum current: 13A
Maximum load: 3120W
Typical power consumption: <0.5W
Internal rechargeable, non-replaceable battery
1. Display current clock.
2. Display line voltage.
3. Display line current.
4. Display line power.
5. Display peak line power.
6. Display accumulative total electricity usage.
7. Display total on time and total electricity usage.
8. Display line frequency.
9. Display power factor.
10. Adjustable max. overload current, max. overload warning.
11. Adjustable price / kWh - 2 price tariffs.
12. Set combinations of days or blocks of days.
Note - This product takes a few minutes to charge from the mains and may not activate initially.
Was £12.99 Inc. VAT
Only £9.80 inc VAT.
ORDER NOW
Energenie 6-way Donut Extension Lead with Cable Tidy & Surge Protection @ £9.98 inc VAT
Energenie presents the innovatively designed 6-gang Donut extension lead. The product is surge protected to protect all the electrical products that are plugged in to it from any unexpected spikes. The circular shape makes it perfect to fit under a desk and provides a solution to avoid the constant tangling of all of your wires.
The unique shape of the housing provides a means of gathering and routing the power cables of the appliances plugged into the sockets. The mains cable of the extension can be wound around the base for storage.
Technical Details:
Sockets: 6
Cable length: 2 metres
Maximum total current: 13A
Maximum total load: 3kW
Surge protection active lamp
Illuminated power switch
Surge protection:
Protection: L-N, L-E, N-E
Maximum total energy dissipation:
525J
Energy dissipation L-N, L-E, N-E:
each 175J
Total max. spike current: 18000A
Max. spike current for L-N, L-E,
N-E: each 6000A
Max. spike voltage: 775V
Response time: 8-20ìs
Was £12.98 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Energenie 30 Minute Rundown Timer @ £5.99 inc VAT
This rundown timer will switch off the mains power to your appliance after 30 minutes.
Suitable for:
• hair strighteners
• irons
• curling tongs
• electric blankets
• bedroom lamps
• bedroom TVs etc
Voltage: 220 - 250v ac 50Hz
Maximum load: 13A, 3kW
Manual reset button & indicator lamp
Timeout period: 30 minutes
Was £7.88 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Energenie Radio Controlled Socket - 3 sockets + 1 Remote @ £13.98 inc VAT
Switch o! appliances wasting energy in Standby such as older TVs to save money and reduce your carbon footprint. Devices left in standby may also be a fire risk and it is safer to switch them off. The remote control does not require direct line-of-sight to operate. It will work even when the socket is hidden behind furniture or in an adjacent room up to 30 metres range.
• 3 sockets + 1 Remote
• 4 channel remote control plus ALL on/o! buttons
• Socket will learn remote control key code
• On/Off indicator light, manual on/off button on unit
• More than one socket can be programmed to the same remote control key
• 13 Amp rated to BS5733
Was £17.50 Inc. VAT
Only £13.98 inc VAT.
ORDER NOW
Energenie PC Automatic Standby Shutdown Extention Lead @ £12.98 inc VAT
The Automatic Standby Shutdown extension lead for Personal Computer Systems reduces the energy wasted by leaving your computer equipment in Standby. It will recognise when you have powered down your desktop computer and automatically removes the power to the 4 controlled sockets and any peripherals plugged into them.
The 4 controlled sockets may be used with your desktop computer, printer, monitor, scanner etc. There is also one permanently on socket for equipment that requires continuous power. Use the button on the flying lead or on the housing to switch back on.
• 4 sockets with automatic standby shutdown
• 1 permanently on socket
• 1.5m mains cable
• 1.3m restart lead length
• Voltage: 240V ac 50Hz
• Maximum current: 13A
• Maximum load: 3kW
• Standby power consumption: <1W
• Manual set-up
• Manual on/o"
• Indicator lamp
Was £16.98 Inc. VAT
Only £12.98 inc VAT.
ORDER NOW
Energenie Radio Controlled Extension Lead @ £18.98 inc VAT
A 4-socket radio remote controlled UK Extension lead. Each socket may be individually controlled via the radio frequency remote control or all sockets may be switched on or off simultaneously. Suitable for people with restricted movement and ideal for controlling appliances in inaccessible places. Wide socket spaces for use with appliances that have bulky transformers.
• Remote control will operate through walls and ceilings up to 30 meters.
• Surge Protection protects all of your devices from power spikes
• On/Off indicator lights
• Sockets: 4
• Cable length: 1.5 metres
• Maximum total current: 13A
• Maximum total load: 3kW
• Standby power consumption: 2.3W
• Protection: L-N, L-E, N-E
• Total max. spike current: 18000A
• Max. spike voltage: 775V
• Response time: 8-20ìs
Was £21.98 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Energenie Power Management System with Advanced Surge Protection @ £38.99 inc VAT
Energenie PMS is a Power Management System with advanced surge protection. The managed sockets of this unit can be individually programmed from a personal computer to switch on and off according to either a timed schedule or based on events or controlled manually from the keyboard. The unit can be pre-programmed and then disconnected from the managing computer to use elsewhere.
The unit can be assigned an IP address and/or a network name as a shared LAN resource and can be afterwards accessed and managed from anywhere within the local area network or Internet.• Also available as PMS-LAN and PMS-WLAN (wireless). The built-in web-server can be managed from any computer running Internet any web browser providing global internet access.No external IP-address at home? Create your own user account at EnerGenie.com to manage your EG-PMS-LAN via the Internet with any PC or smartphone. Switching on your coffee machine before setting off for home becomes a reality.
• 4 individually programmable sockets, 2 unmanaged on sockets
• Computer programmable via USB port
• LAN access as shared resource
• Advanced Surge Protection
• Manual switching of every socket on and off via control window on the PC
• Pre-programmed timed switching
• Pre-programmed event based switching
• Timed switching operates when not connected to computer
• Voltage monitor
• Computer software supports multiple PMS units connected to the computer
• Management via the LAN and Internet
• Command line interface support for user software applications
Tech Specs
• No. of sockets: 4 managed, 2 unmanaged
• Max. socket load: 13A, 3kWatts
• Max. unit load: 13A, 3kWatts
• Voltage rating: 220-250V~ 50Hz
• Surge Protection: L-N, L-E, N-E, 375 Joules
• Unit standby consumption: max 2.5Watt
• Ports: USB 1.1 or 2.0, (350mA)
• Compatibility: Windows 2000, XP, Vista, 7
Suitable for use with
Computer Systems
Aquariums and terrariums
Heater & pump control
Air conditioning control
Lighting control
Laboratories
Saunas
Battery charging eg golf buggies and caddies
Was £44.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
I'm guessing you plug that into wall, then your surge extention into that?
Might get it would be useful to see how much power is used.
Are these compatible with the bulbs . . . . :D
Seriously though, look good products and well priced. I do like the donut extension, good idea! That last one looks VERY tempting for a geek like me . . . . Any chance of a review, or a look at the control system for it?
correct. it just measures what you are using. this is the product that lead me to research into Energenie as it seems to be the 'GO TO' product for power meters.
I plan on grabbing one for myself to see how much overclocks affect power consumption :)
they are good quality from the products I have seen so far.
I am keen to get the PMS myself. the price will be back up to £45 in a few days. I really cant hold this pricing for long.
Very tempted by the Power Meter to show the 'rents how much power their kit uses on standby. Excellent prices guys.
We have been working closely with energenie to provide brilliant pricing. Their product range is expanding all the time and they are UK based, a great company to support
our stock is due to arrive tomorrow,
remember these prices are pre-order only and will be changed as soon as stock lands.
stock is here - all pre orders shipped :)
just had a quick go of one of the power meters in the Ultima XXX
switched off it drew 2w
desktop idle it drew 276w
under LinX it drew 346
with LinX and Furmark it drew 860w :eek:
interesting figures to say the least.
I'm grabbing one today to check the differences in power draw from my system when clocked/not clocked
