- 13 Jan 2004
- South East
I really want someone to detail my car for me as I can't be bothered to do it myself. Most places charge like £200+ though
I sent the link to the email address listed on your profile (Hotmail)
Russ.
frankly I wouldn't bother with the clay. I got one and did the 300zx the other week, took a lot of time and effort. Was super smooth and lovely after, but just 1 week later it was back to exactly how it was before. A waste of time if you ask me.
If you must, then get a more 'aggressive' clay.
Just took the car to the clay bar. Results are good, will try and get some pictures up later. Surprisingly easy to do as well, I was expecting it to be a right slog.
Claying is better than polishing/waxing (well easier to do).
Takes all the ground in grit and contaminants from the surface layer of the paint, giving the bodywork an extrmely smooth, glossy feel which makes it easier to wax and wash, etc.
Also makes it easier for companies like Meguiars to empty your wallet.
If its lovely and smooth what would a more agressive clay offer?
Sitting on OcUK is easier than climbing Everest too.
How can you compare two totally different things![]()
Eh? Claying is bl**dy hard work. Polishing & waxing can be done with a mechanical polisher......I mean its easier to clay, than it is to polish or wax.
