Well done for posting this... my other half has just gone and bought these off the back of your post
http://www.fiio.com.cn/product/index.aspx?ID=24&MenuID=020301
http://www.fiio.com.cn/product/index.aspx?ID=12&MenuID=020303
Haha, it had to be done! Tech > Lipstick & Handbags. fact.
the E11 is the best one fiio make, the L3 is also their best line out cable but its the exact same as the L9 apart from different shape.
people prefer the L9 as you dont need to bend the wire (causing wear and tear).
if your L3's wire wears away then get an L9 next time round.
which ipod will you be using them on?
if its a touch then the Equ app is a must buy. also which headphones do you use? as the E11 will only really shine on headphones worth over £100.
I've done a fair bit of research and it definitely seems to be the best option for the money.
I've got a pair of Denon AH-C710: http://www.denon.co.uk/uk/Product/P...phones&SubId=InEarHeadphones&ProductId=AHC710
Fantastic earphones but a bit of better amplification wouldn't go amiss. I'll be using my iPhone mainly as I listen to a lot of music at work. Which Eq app are you suggesting I use? I'm happy with the standard settings, but open to suggestions.
