Is that actually ICS then or some modified ROM?
It's a Gingerbread themed ROM with the leaked ICS launcher and Music 4.0, which is why he only shows the music application in detail and doesn't show the "About Phone" in settings.
Just some idiot trying to get YouTube hits.
Anyone got an answer to my question about using the gs2 as a hotspot? I can connect to it OK to it but it just doesn't share the phones data connection and I can't see why. Cheers.
Your using the hotspot feature, right?
Seeing as nobody knows why the USB jig doesn't work on my phone, I've got another teaser for you guys:
Why do you have to turn the noise cancellation on in every call if you want it? Is there a way to enable it by default?
When the phone is off and you put the jig in does it put the phone into download mode automatically? Assuming you flashed the old bootloader putting it in bootloader or PDA already.
Old bootloader tarball: http://www.multiupload.com/LQQBRQVJUD
Thanks for the link. I already saw you'd posted it earlier though, so I have actually tried that already. I flashed it successfully but for obvious reasons I don't want to keep trying this on a brand new phone in case I brick it. So even with the old bootloaders it still won't come on. I'm thinking Samsung may have disabled this functionality somehow? I don't know how though.
Other option is to buy another jig, I don't have all the kit to make one easily, and I guess they're not that expensive.
Just updated to XWKI4 and they changed the default font to be boldwhy do that and not have an option to un-bold it? Never thought something so small would drive me insane
