AMD Bulldozer Finally!
Hehe I do that even though I'm only on a C2D. In fact I do it a lot less than I used to cause installing things is reasonably fast on this, but I used to do it a lot back when I had a single core (Athlon XP 1700+, then moved to a 2500+ XP-M @2.2). Since everything was going on a single hard disk too it probably slowed things down MASSIVELY, but I still did it, even when it led to everything crashing and burning - I was just too impatient!:D
LOL, I'm a patient man but if i think i can get away with more at once i will.
Bulldozer is actually smaller than Thuban and IIRC they are only buying usable chips from Global Foundries,meaning the latter is probably taking the hit.
The FX4100 uses the same die as the FX6100 and FX8100 series and is around £90 to £95. The FX8120 is around £160 to £170. I suspect they could make a profit even selling the FX8150 at £140.
Bulldozer FX 8150 is two billion transistors...
SB 2500k is less than half of that.
The Phenom II 1100T is over 900 million transistors.
Thuban is 346MM2 and Bulldozer is 315MM2.
I was talking transistor count, but which do you think is harder to make, Thuban or Bulldozer? That'll be Bulldozer, which is running hotter and consuming more power with horrendous yields? Bulldozer, which would make I assume the die size frugal in this situation.
Again they are paying for usable chips as been mentioned in multiple news articles. So it is Global Foundries which is taking the main hit here,not AMD.
On top of this it really seems they are diverting a lot of Bulldozer production towards commercial customers. They are supplying 38400 16 core Bulldozer CPUs to Cray for Oak Ridge National Laboratory. That basically means nearly 77000 8 core Bulldozer dies just for one customer and that was known before launch.
I hate the theory, but end of the day, we have no 8150 stock, all the theory talk isn't going to change that.
The stock we have is failed 8 parts so far.
At least as regards the consumers, we don't know if they've supplied all these CPU's yet for commercial market.
Is that per core/module, or for the whole chip?
I really wonder whether they needed 2MB L2 cache per module. If the idea of getting each module to share 1 FPU was to keep the transistor count low, they more than made up the difference by having such a large cache. It's twice as much (per core, four times as much per module) than Sandybridge. Would love to see some benchmarks of parts with some of the cache disabled to see how much difference it actually makes.
ocuk had some 8150 today. mine as be shiped.
most be a back log pre order list
Time for a 'user feedback' thread then? :p
Will you be overclocking yours Gareth? I'm interested to see how the average user gets on with it.
Seems like a hand full though, I know there *was* stock, because it showed up in the products, but when I looked at it, it's on pre-order.
Are you still going Intel aswell then?
yes.. im most likely sending the 8150 back under DSR
i have a question if i open/try the 8150 can i still send it back under DSR, if im not happy with it?
Martini, do you work for OCUK?
Nope, I'm a no-body, I just speak my opinion.
The 8150 isn't in stock right now is it? We know it's been in stock, as it's showed up on latest product (Which products do when they arrive stockwise).
From what I heard, there was a few hundred 8150's heading for the UK E-tailors, OCUK seemed to have gotten priority.
You could sell the cpu on an auction site. Given the rarity of the CPU, I'm pretty sure that you should be able to get back almost the full price you have paid for it.
If it were me, I would sell it, rather than returning it under DSR...if only because you have used the CPU and probably overclocked it as well.
if im not happy with a product surely thats what the dsr is for..
shoping online is not like walking in a shop and able to look the product working and try it yourself before buying
Depends on your interpretation, you're well within your consumer rights to do that, however, OCUK can't re-sell that CPU as brand new or OEM, it has to be B-Grade, in some ways the E-tailer gets "kicked in the teeth" with DSR.
