- 15 Sep 2011
any reason why its coming up with Intel(R) HD Graphics Family 8.15.10.2509 3862Mb?
Seriously impressive for a laptop!!! What's the temp like on it? Does it run hot?
Back on standard CPU clock to test new xfire 6950 config, I think this puts me at #22 on the ATI list
Finally put my 470 through Heaven. Beats the other single 470s on the list
GTX 470 @ 850/1700/1800 core/shader/memory
930 @ 4GHz
Probably be able to get higher on both the GPU and CPU, the GPU clocks are my folding stable core/shader and a little bump on the memory just to see what happened.
Next time I'll do the screenshot better heh, just looked through and realised almost everyone else has saved to HTML and screenshotted that.
There you go![]()
Heh, I was going to post it like that but I figured I would end up annoying people with lower resolutions.
I've now broken 1100the card's still clocking higher but I'm now running out of room on Afterburner's core/shader clock slider.
Edited.
Do you need to enable unofficial overclocking to allow a greater range?
Hmmm, this seems really low - why isnt it showing my ATI 2GB 6950? o_O
Is that the Virtu application?
Ive tried running with it on and off and has made no difference, although on the card icon it says discrete??
