2600k + motherboard advice
i've been looking at a Asrock Z68 Extreme4 Gen3 board, it looks like it has everything i need on it , what do u guys think?
but would i need new ram? because mine need 1.7v for stock settings 1600 7-7-7-20
Make sure it supports tri-fire if you are going to run that 6990+6950, remember the 6990 is treated as crossfire, so if the board doesn't support it, it wont work.
hey gareth - just got mine literally setup - still installing drivers etc:
So far so good - I like the UEFI bios and its simplicity. Will report back once its setup in a couple of days as I gotta shoot to birmingham 2nite :(
ok i want a honest answer..
is it worth me doing the switch to intel which will cost £451~ for a Asrock Z68 Extreme4 Gen3 board + 2600k + new cooler.
ohhh crap i just thought i will need new cooler also..
grrrrrr
Why will you need a new cooler?
1156 brackets are common place and have been for a while?
well i guess i can drop it to 1600 9-9-9-20 1.5v
how about that motherboard?
Board's fine, 1.5v sounds fine at 1600 CL9.
The Crossfire on a 6990 is internal, it doesn't make a difference if the board doesn't support Crossfire, although in this case he needs Crossfire support obviously as he's doing two cards, although not "tri-fire", as that's just a crossfire configuration, 3 way is it not?
Yes it's worth it, you should see an improvement in game frame rates easily.
this is what im thinking of getting
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM
Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard
Thermalright Venomous X Black Edition CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366/AM2/AM3)
total price £451.96
going from a 1090t to a 2600k, how much in % will i see in performance across all things ?
1090T at 4GHz to 2600k at 4.5GHz, not a huge amount for gaming if at all in terms of framerate, 5-10% max? Certainly not £450 worth.
so now it's not worh the upgrade?? i was going by Martini1991 said it was worth it
wouldn't ivy bridge cost more?
