Battlefield 3 RETAIL Performance Thread
Some more screens to get you salivating even more.
http://www.pcgamer.com/2011/10/25/battlefield-3-screenshots-celebrate-us-launch/
I'm using 11.9 with 11.9 CAP 3
Two 6950s in crossfire and with Auto settings (mostly high with textures to Full) and at 1920x1080 I get around 70-100 fps on all maps with my cards at 80-99% usage.
I've since changed resolution to 1680x1050 and the game feels so much smoother, getting 90+ fps on all maps with my cards running at about 70-80% usage, so it's certainly a graphics intensive game.
Only reason I'm using 11.9 is that the 11.10s didn't allow me to play in crossfire, the screen would just scroll and flicker making playing it impossible.
To fix the stuttering remove CAP 3 if you're using Crossfire, no need to drop drivers down from 11.10 Preview 3.
I did this but still get massive shuttering. Sometimes it will lock up for 2 seconds or I will skip forward massively. Are you running any profiles at all?
11.10 Preview here
W7 64 bit
i7 @ 3.4Ghz
6GB 1600Mhz RAM
6970 2gb @ 950/1415
Intel x25m 80GB SSD
Gigabyte UD3 x58 mobo
Corsair TX 950w PSU
LG W2363D 120Hz monitor 1920 x 1080
Antec 902
Setting on Ultra with MSAA and HBAO off ! Most useless things I've ever seen, I really cannot see a difference.
60-100fps singleplayer.
Runs very nicely, well done DICE. +rep for you
On a 5970, removed CAP3 and dropped back to 11.9, still getting massive stuttering in some games (i.e. freezing for a second every 10 seconds).
Makes jets/choppers unplayable...
Auto settings look great and run decently (not optimally), I tried putting it to ultra and instantly got around 20-25fps.
Really looking forward to next-gen stuff. I can't remember the last time I had to turn down details!
Are there any benchmarks comparing different cards in BF3?
Trying to decide if I should try to crossfire my 5850 or upgrade to a single 6970.
On Caspian border I have been getting mainly between 60-80's on high setting @ 1920x1080.
My specs are:
1055t @ 3.2ghz
x2 5850 @stock
8gb ram
running 11.10 drivers + 11.9 caps.
I have crossfire 5850s at stock and can play on High settings, SBA off and no AA. It looks really nice and getting minimum 55fps. Id imagine with driver updates I'll get the minimum 60fps I long for. What's the rest of your system spec?
i7 920 @ 4Ghz
6Gb Ram
Corsair HX850 PSU
Crucial M4
24" Monitor
I should be ok with a better graphics card right?
Yo Elrasho, are you getting full usage on both gpus with the 11.10s?
I think I'm going to need to do a frametime graph for this.
I think people here are suffering two different types of stutter.
The one where the game actually freezes for 1/2 seconds I beleive is caused by the lack of VRAM. To fix this, try turning your texture quality down.
The second stutter, which is what I am suffering from is a lot like a Microstutter. The game doesn't freeze but in parts, even with high fps, feels notchy. I think this is caused by poor drivers. Will remove the CAP's this evening and report back.
i7 920 @ 4Ghz
6Gb Ram
Corsair HX850 PSU
Crucial M4
Get a 2GB 6950 and you'll be happy. I kinda regret not going down that router, I only just bought another 5850 last week. Still 5850 CF is faster than a single 6950, and then I'll probably skip the 6xxx series cards and get a 7xxx series when they are released.
What resolution are you going to game at?
The first type of stuttering is not a VRAM issue. This stuttering went away after a week into the Beta and I hadn't changed anything. Its something else.
