Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Pardon my ignorance, but BF3 won't let me play yet until the 28th. How are you lot getting around that?
VPN into a time zone which has the game activated already, do the release day check. Deactivate VPN and play.
Lots of us did it on Monday with Korean IPs.
Damn I suck with the jets. Anyone got tips? I fail at both tailing and being tailed :p If I'm not simply owned as soon as I take off I'll just get tailed by someone (is it possible to get a rear view like in BF2?) and find it impossible to shake them. When I attempt the same I find it hard to regulate my speed so I normally just fly right past them :/
Any confirmation on stat reset?
Stats are not being reset, i don't have the link to hand but someone put up a tweet from dice saying there's not. As far as the jets go i'm having the same problem i used to be good on BF2 with jets but im crap on BF3.
Does anyone find when flying that if they want to mae a tight turn they are having to constantly move their mouse (forward or back depending on how you are setup). I find using WSAD and arrow keys allows you to turn allot faster but it's harder to aim.
uber micros between keyboard and mouse? :D
I'm using ATI and I experience no stuttering at all. I'm surprised how good the game looks but still performs well.
When will unranked servers be available?
Because when you use a key binding for essentially aim for you (cursor keys) you're applying a full force. The same happens with a mouse when you pull / push it as fast as you can, as it's a linear axis, not a single switch saying 1 or 0, it says 0, 0.1, 0.2, 0.3 etc; you get the idea ;)
What GFX card you have? I run the game on ULTRA with high shadows smoothly, then randomly it will start stuttering, seems to happen the longer I play the worse it gets. No not overheating.
HD 5800. I'm only using high graphic settings with 4x AA/AF. Res is 1920x1200
Is there a queue system on battlelog somewhere? only thing I really miss from the BC2 browser. Can't see one but thought I'd double check in case I'm being a bit derp.
Status
