Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Ok i turned of Upnp, i think thats fixed the dc'ed but the game still doesnt feel smooth, It keeps gittering :(
I change my clock speed and did all those settings, still the same.
I'd uninstall and driver clean all ATI drivers and resinstall.
I am running an i7 920 stock, 6gig ram and a 5870 and running smooth on everything high.
Glad the UPnP setting worked! :)
Anyone know what wrong with this **** called origin ripoff. I get the game, install into my account, update my drivers and then restart the computer. I then try and start the game but I cant login even though I am putting in the correct password (getting incorrect details error). I then click on forget password and it says it will send the validation key but I am not getting anything on my email.
So I bough this game yet I cant seem to login and its not sending me any validation key to my email to reset my password. WTF is going on?
Yeah i had the same exact problem. Biggest joke of a program i have ever come across on the PC.
That code in the email, dont put it in the url like instructed. Put it in the validation code bit on the origin program.
I signed up with Rybo89cfc like all my gaming profiles and for some reason origin decided that i put CFC_Rybo89........ Stupid thing.
I did that this morning, not running ati though, I have a Nvidia 570.
My bad, should have said Nvidia.
Hmmm no idea to be honest mate.
Your set up should be running the game fine, have you tried different drivers? It must be a software issue and nothing to do with the game or the majority would be having problems.
Just to say as I bad mouthed CJS CD Keys earlier in the thread, after a few emails I have received the key I didn't receive at first.
"Download Now" is greyed out in Origin. How comes some people have the game already?
I purchased my copy today...
Haven't received an email with a key?? Is this common?
Just had a few great games on the 32 player TFU Server. Must say I do prefer the 32 man servers over the 64's.
I'm feeling that too. But i think with a squad of 4 people all on headsets, 64 could be really fun aswell. It just needs that bit extra coordination or its all just a bit too chaotic imo!
Purchased from where? Was it through origin or via another site that sends keys? Just redeem your code in Origin and you should be able to download.
Flares are 100% working, as you said, you just need to time it right. Don't use them until the locked sound becomes hideous. There's 3 stages to the sounds.
The first beeping noise is saying that someone is tracking and locking on to you.
The second stage noise is that they have acquired a lock (this is where you should try and evade, turn hard etc to get out of their target reticule).
The third stage is where you deploy flares. This is a nasty sound that basically means rockets are locked on to you and smashing through the air as quick as they can to get to you. Deploy the flares here. I usually wait a second or so before deploying them because most pilots will fire off both heatseakers - which has a slight delay between shots, so I try to make sure that both rockets are in the air before I dump flares! Otherwise they could just save the second rocket until you're pass the flare range.
There you go, Jet Survivability Training 101 ;)
*EDIT*
From this, you should learn how to counter the above quite quickly. Try not to fire both missiles at the same time if you know they haven't dumped flares. If they have dumped flares, hit them with both rockets.
Also a tip, as you launch the missiles, swap to the chain gun and get a few hits with that. The reason being is that both rockets will NOT destroy a jet, only disable it and send it hurtling around in the sky. Most people will jump out, meaning you get no kill. If you can land a few good main gun shots on it before or as the rockets are hitting it, you'll get the disable, kill and destroy bonuses at the same time, instead of missing out on the kill and destroy. ;)
Thanks again :cool: I will definitely keep this in mind.
Yeah I recognised that enemy lock-on on your jet has three stages basically simulating the actual lock-on from the enemy weapon. I did get the feeling that 3rd stage is where missiles have been fired at you. In one or two instances I did deploy flare at 3rd stage but got hit. I think may be because the enemy jet was already close by.
Mobile AA although highly effective are pain to avoid :p
When it says 'enemy jet 100% disabled', how much jet life has been decreased by actually? Sometimes it seems that after they have been disabled, they carry on flying.
Yeah runs great on 4gb for me. Check task manager and you see the game using less than 2gb RAM.
People have been looking at total RAM usage when playing BF3 and seeing close to 4gb or over if they have more, but this isn't a proper indication of the RAM usage of BF3. Windows will just "use up" this RAM "reserving" it for if it needs it.
Check task manager and you will see you don't need more than 4gb :)
Right I have reinstalled BF3 and I am still getting the CTD problem where it just wont load.
I was playing fine yesterday and I have the 11.9 drivers on a single 6870
Giving up will to live to the point im tempted to just get it on the console
Gonna give the 32 player ones a go later. 64 man just seemed a bit all over the place.
Status
