Caporegime
- 18 Sep 2009
- Dormanstown.
It's a shame AMD can't get 10 8150's to the UK
Oh and before it looks as if I am some AMD fanboy...I'm not.
I couldn't care less who has the best CPU...I buy the best CPU, at the time of purchase, regardless of brand.
All I'm saying is that AMD's new CPU is not bad...it just isn't the best. As such, as long as they price it lower than the the 2500k, they should be fine.
only in in encodingLike you stated, it performs at around the same level to AMDs current best CPU. In otherwords...its not a bad CPU. It just isn't any better.
it performs worse than the phenom II clock for clock in gaming ect, and in encoding the BD 8x performs same to the phenom II 6x clock for clock even tho it as 2 cores less
how is that not bad?
. That's not "clock for clock".
it as to be clocked to 4.5-4.6ghz to get to the same level of performance in everything except encoding , of a phenom ii 6x at 4ghzGuys, this CPU clocks higher than the Phenom. Once it has clocked higher, it will outperform the Phenom in pretty much everything.
but amd as been working on it for so many years tho, theres no reason for thisAs I said, AMD have not produced a bad CPU. This is version1 of a brand spanking new architecture and it would've been a miracle had the first version been an Intel beater.
I realise that a lot of you were expecting BD to be an Intel beater...but after the delay this was never going to happen. AMD weren't delaying the launch because the were all going on holiday - they delayed it because performance was really bad. The BD isn't as good as some of you were expecting (it is pretty much exactly what I expected), but it can run neck and neck with Phenom once it is clocked high.
With regards to people stating that core per core, it performs badly...well, that may well be the case, but it does have the extra cores...so what's the fuss? You wouldn't disable cores during a comparison...what you would do is run the CPU in its best form (or run both at stock).
This is almost exactly the same scenario as when P4 took over from P3. The highest clocked P3s outperformed the lowest clocked P4s, BUT the fact was that the P4 could be clocked higher and once this was done, it comfortably outperformed the P3.
Hopefully, once production ramps up, AMD should get some volume into the stores and prices should reduce.
but as i said amd as been working on it for so many years tho, theres no reason for this ..... some people are trying to find reasons or something to make out it's fine for this crapeveryone is outright crucifying the architecture based on the weak performance (mostly lightly-threaded stuff) based on the first silicon, first available revisions, first everything, look at it this way it is a brand new architecture running on a very immature process with tons of niggles and issues. at the end of the day, all of the people crucifying aren't architectural designers or anything like that yet going on about what has been done wrong and the likes. I for one say give it a chance to reach its second revision before everyone outright claims it is the worse thing ever released in the whole universe, ever.![]()
So does this all mean i shouldnt ditch my 955 any time soon....?
You've spent like 175 on a mobo, then 90 on an interim CPU for BD then Bulldozer, when you could have had an Intel at the same price and better.
This is not AMD's fault. This is the user's fault who didnt want to buy a 2500k (which in my opinion is one of the best CPU/platforms ever). The user who was hoping to upgrade to BD, was clearly expecting an Intel killer.
By delaying BD for 6 months, AMD made it pretty clear that BD1 was not going to be great. Remember, a 6 month launch delay means that things really are not working as planned. A 6 month delay is VERY serious. So much so, that one of the big wigs at AMD was fired for it.
