external to internal
233
233
21 Nov 2004
Wishaw
just picked up a st320005exd101-rk seagate external usb drive.
its usb2 therefore painfully slow. silly question but can i open it up and find a sata2 drive inside and just do a normal hdd install?
another quick q
will i loose any data i've put on the disk if i remove it from the caddy and install direct?
well just buthcered my £70 quid external drive to find i have this exact disk inside :)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-244-SE
hmm bare drive costs £130, drive with usb caddy a power supply and gubbins cost me £70.
Foxtrots top taxi driver tip, buy an external and make it internal :)
oh and getting just a slight impovement over the usb caddy performance figures
usb average read speed 40MB/s on sata with my old ds3r 775 an average of 112 MB/s and 195MB/s burst speeds tempted to pick up another external tommorow and go for a raid0 array :)
Are you sure its that drive? The one you have listed is 5900rpm. The external drive is listed as being 7200rpm - so it should contain a 2TB Seagate ST32000641AS Barracuda XT 7200rpm
Also how easy was it to extract the drive from the caddy?
The drive is easy to remove however it is difficult to get the expansion case apart without breaking all of the thin fragile clips and part of the drive is taped to the metal cage with silver tape so it would be evident in an RMA that the drive had been out of the cage.
AD
have to disagree, mine came apart with no issues, just have to be careful to slide it out gently. currently dropped a 150gig drive into the caddy to make use of the caddy ;) went back together without any issues and its working fine with a 150gig drive.
now if i was a rotting sod i'd take it back to the catalogue shop and get a refund or exhange :)
AD
only tape on mine was 3 small squares holding the wire for the activity light onto the drive :)
currently sitting in the living room watching talladega nights, i'll go pop the side off my rig and double check shortly :)
Except hard drives are exempt from being returned unless faulty :(
bit late now but it would have been so easy to do that on day of purchase. :)
walk back in an hour after buying it and state its faulty(after i've swapped the 2tb out for something else)
makes you wonder how often people do that
