- 19 Oct 2002
- Torbay, Devon, UK
10.10 preview 3 + Offical CAP 4. I get no BSOD at all. The only time my game locks up is if I change a graphics setting. Which is a real pain.
Sound affecting performance?
That's what I'm getting, pair of 5850's at 775/1125.
Think I could tweak the settings at all? Getting stead 50-60 fps, gets a bit choppy when it gets busy though, not often.![]()
are they 1gb cards? how are you managing ultra textures if they are without freezes when you look left and right?
i get it on my 5870 until i drop textures and shadow to high and it's the same on my brothers 5850 CF,
You getting looping sound when you BSOD?
I may turn off HT tonight as the stuttering is annoying me. Other than that, loving it with my GTX580 at 1920x1080 all Ultra, 2xAA, High Post AA, HBAO
Yup! Cannot figure out what it is 100% but strongly feel its lack of AMD drivers. Could be MSI AB with punkbuster!
Used to get that in BC2 with afterburner running.
I dont stutter or struggle at all with MSI AB running in the background. Might be down to drivers thenI could try putting on V-sync and see if i begin to stutter at all.
A cure for this was to go into the afterburner directory and rename the file RTCORE.cfg, then restart afterburner. You do loose fan speed monitoring in the osd on nv cards, not sure about ati's.Used to get that in BC2 with afterburner running.
Are the settings ideal?
