Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
It sounds to me it would take a lot more searching before you find another £700 jag in such good condition.
Mull it over?
Get it bought man! (Just out of curiosity, did you turn up to view it in the 911?)
Nope went in 306, as I was trying to barter down.
ST220?![]()
Go for it Gibbo, you've had a look and even test driven it (unlike some people on this forum that buy a car on ebay)
Hope it all goes smoothly.
VFM that, can't do much better really. Omegas go for similar, but then you wouldn't have a Jaaaaag I suppose
You'll no doubt need 4 new tyres though if the previous owner didn't even bother with servicing.
[TW]Fox;20452017 said:Not generally you can't, no. He's done very well indeed and I rather suspect it doesn't look quite like that immaculate one in the picture.
The cheapest possible S-Type on Autotrader right now is £1k, and the first page or so is usually junk anyway.
Checked them, three had 4-5mm and one had 2-3mm. Half decent tyres are £80 each for this which compared to the £400 per each rear on the 911 is cheap.
Basically £1k you get a Jag with 4 new types.
Where do I sign up?![]()
[TW]Fox;20452386 said:They are pretty quick actually - 0-60 comes up in 6.9 seconds. Bonkers thirsty for what it is though, it has a whopping 270g/km of CO2 emissions and 25mpg combined! From a manual six pot!!
its definitely a sensible option for the winter Gibbo
rear wheel drive snow fun![]()
