Permabanned
- 21 Apr 2008
so basically its igla heaven until pilots get the flares and then you don't have a chance
Really enjoying itGlad the servers are more stable now.
There are some crazy high ranks already though. Seriously, do some people play this nonstop or something?
They need to make it more obvious where on the map I will be spawning. Every time I spawn, I have to pause for a second and really look, as half of the time its just not obvious enough.
Also, another thing that gets on my ****.... When one of our flags is getting captured say 300 meters away or something, it doesn't make it obvious as to which direction it is. I will look around trying to figure out which flag is actually getting captured but by that time it's too late.
Planes are USELESS on this game
So, best weapon for the Engineer anyone?
Unlocked all but the last one now and can't decide between the Scar-H or the A-91
another thing which is stupid.
Is if you bail out of a heli/plane you could be in 'out of bounds' area. So you die within 10 seconds. I am sure on BF2 you just ended up with a long walk. Think the out of bounds is not sensible when in aircraft.
(PS3)
Also you can shoot lights out in tunnels etc, but yes the bulb stops working/shining but it does not actually dim that area, which would help for sneaking around.
I use the minimap to know which flags are being capped. The diamonds from left to right are in sequence A, B, C, D etc. Also the world icons at CPs show you where there is conflict and also there is a circular count-down or count-up telling you what is going on.
I don't really know what you mean by making it more obvious where you spawn. When you move up and down through squad members and capture points it clearly shows your selection on the map and it also shows you a follow cam of where you will spawn on the main screen.
