My 2312 is vastly inferior to my ancient NEC 20WGX2. IPS glow doesn't occure on my NEC until a pretty extreme angle where it mildly turns orange, the colours are much more vivid, blacks are deeper and whites are brighter.
It does have a minor edge on input latency and a nice increase in size. The 16:9 ratio is also perfect for console gaming. My main concern is that the IPS glow is far more pronounced in the bottom right corner, which leads me to believe it's a screen defect, although many others have complained about the glow in this location too.
I have a question about the USB ports on the U2312HM. Can I plug a usb hard drive into one of the ports and play back MKV files? (i.e without the need of a pc?)
Thanks
My old NEC is fantastic even at pretty severe angles on a black screen, I just wish manufacturers would stop cutting so many corners recently
The buzzing appears to be getting louder too, and has been verified as abnormal by dell![]()
<Pokes Baddass about U2212HM review>
it's with me, but i'm just finishing the AOC i2353Ph/Fh review. within a week or so hopefullysoonit's with me, but i'm just finishing the AOC i2353Ph/Fh review. within a week or so hopefully
This reminds me. Are you still after an SA850? Did they ever get back to you about this if you followed it up.
