- 16 Oct 2005
- Poole
Is there any way to enable AA and remove the 30fps cap? And play with more graphics options?
I cant play without it
What a Pain this game is. I create a character, get into the starting area and it just randomly crashes on me. No set point either, it's completely random. Up until the crash it runs just fine. Then, BOOM, blank screen and the system needs a hard-reboot.
Solo you need melee, but in groups is where i found ranged really grows. If you want to range i suggest kiting.
Some of the skills seemed a bit odd to me. First created a bow/nature char and kept getting melee skills. My basic tatcic seemed to be hover over mob while spamming right mouse button. Not vey exciting or involved. So, I then created a mind/mace guy and that seemed much more fun with the melee attacks and a few ranged.
Same can be said for fire dps. But in the end it's entirely down to player preference so I am just giving you my versions. I am in the process of levelling up a fire dps to see how it compares with the ice dps I already have.
Skill set up didn't look good, too many melee attacks for what meant to be a range class and I don't like shape shifting.
There is no AA in the game. I don't know why people are so bothered about AA. And yes you can turn off vsync in the game. When you get in just hit Esc and then Settings. And go from there.
As for power sets, I highly recommend searching for and then downloading and installing Ultimate DCUO Character Planner. This has all the powers, mentors, weapons and pretty much everything you need on what role you want to play on.
I have 6 characters and 4 of them are of each role: tank, controller, healer and dps. The tank is ice, controller is gadgets, healer is nature and dps is ice. All of them on hero side in pve. All level 30 and well geared.
So long as you know what role you plan on taking...get as many skill points as you can and be sure to spec into weapon trees that give you specific buffs/points for your role. Example my dps requires might and precision so I spec into weapons that give out lots of might and damage crit, the more of these, the higher the damage output. For tank you need dominance and defense. Controller vitalization and dominance and healer needs restoration. Keep those in mind, and you're sorted.![]()
