I've been putting together my new rig for BF3 to replace my ageing E8400 on P35 with 5770, thought I'd make a thread dedicated to it instead of making separate threads in various sections asking for advice...
The bits:
(excuse the bad pictures, I have terrible lighting in my room)
Current issues and plans:
To do:
The bits:
- Silverstone Raven 2 RV02 Limited Edition White
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
- Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard
- Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9)
- Corsair H-50 CPU Water Cooler (recycled from my old system)
- OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card
- I've had to RMA the motherboard because it wouldn't start up, displaying 00 on the dr debug led. Expecting the replacement back on Tuesday.
- Also returned the 6950 as I felt I needed something stronger, still trying to decide what to go for: http://forums.overclockers.co.uk/showthread.php?t=18334351
- All 3 of the bottom 180mm case fans are faulty, they make a very loud clanking noise when turned on. I read that applying pressure to the middle should sort out the misalignment, however this seemed to cause the middle fan to lose a blade. The fan now makes the whole case wobble because of the imbalance so I've left it off for now. I loosened the fixings on all fans and this seemed to resolve the clanking noise issue, but the fans are still too loud for my liking. I watched a Youtube review on this case (same version) and the guy says the 3 fans are fairly quiet. Should I consider replacing all 3 fans or is it worth RMA'ing them with Silverstone?
- I want to fit 2 x Enermax Cluster 120mm White LED fans onto the H-50 in the top exhaust for a bit of lighting in the case to make use of the window, can anyone verify the Clusters will be suitable for the Corsair H-50 in push/pull config and not a pile of pants?
To do:
- Add BitFenix white braided extensions to all cables
- Remove the hard drive cage and add this hdd tray into the 5.25" bays: http://www.silverstonetek.com/product.php?pid=249&area=en
- Replace the rubber pads on the feet with felt or something to make the heavy son of a bitch easier to move.
