The Elder Scrolls V: Skyrim announced
Got a question about the graphics, now i have 6950's Xfired and on Ultra this game looks amazing, however when i start up and run the game it performs terribly, however if i ALT-Tab out then back in again its runs brilliantly, anyone any clue as to whats going on here? i assume its something to do with the drivers or Xfire profile, maybe its not using the 2nd card straight off until i tab back in?
just strange is all.
CAP profiles i'd assume. Always some strange goings on with Crossfire/SLI for new releases.
Have you got Afterburner or anything running? That way you could check each GPUs load etc.
Oh, and does anyone else have odd alt-tabbing in this game? If I go to windows, I can't click the window or alt-tab back into the game, I have to do it twice, first time brings up skyrim but in a window and black inside window, alt-tab again and it goes full screen to the game, odd.
Yeah I have this problem too.. I closed the game and had to restart it.
BTW Go and talk to Lucan Valerius in Riverwood, sounds like James Woods haha.
Sven and Faendal just got killed by a dragon, shame that!
Yes, I have this too. I just alt-tab twice into it.
Then again, I have NEVER had a good experience alt-tabbing out of Fallout 3 and New Vegas either, so kind of used to it.
Having finally worked out how to set shortcuts on a controller (hold favourites and press right or left on the D-Pad) is there any way to have more than 2 favourite shortcuts? I can only select 2 whereas keyboard users can select 9.
I remember when Morrowind came out, I was amazed at the graphics, the raindrops spattering on the road etc were truly cutting edge, but that was 2002 !!! 10 years ago!!!
does anyones skyrim have these effects? someone claimed they did yesterday and reckoned my game was bugged or something but it rained again earlier and i could see really poor ripple effects in a river if i examined it with a magnifying glass but no actual wet look to the game world
I just realised there was a GFW logo on the box. I pressed the home key expecting a GFWL screen to pop down. I was happy to see nothing happened.
Im in a dungeon trying to kill a bandit outlaw with a hunting bow :( im stuck...iv got it on hard and dont really want to turn it down!
Dont know if it was posted already but since people are talking about negative crossfire scaling I found a fix over at Guru3d. Either force the Oblivion profile using RadeonPro or use this file.
Originally Posted by grimeleven of Guru3D
Another method it to use the "dll" file to force the profile, i've just tested it and it works, same FPS boost.
Place the "atiumdag.dll" inside the zip, into your Skyrim folder, the game will load that file on launch.
http://www.megaupload.com/?d=ICEDIU66
Not sure if it's been posted yet, but press ¬ for the console, and type fov xx to change the crappy default 60 field of view.
Much thanks for this. I've been playing it in third person for this reason.
What races/characters have people been building? Just curious :D
I decided to go for a Nord, and am currently working towards becoming a frost battlemage with a shield. I played a thief/assassin with a bow and dagger in Oblivion, so just fancied a change.
Can you use the smithing perk to make bows or make the ones you got better ?
I can only seem to make swords/axes/armor:confused:
Thanks.
I improved my bow on a grindstone to make it a (Fine) variant, it increased the damage by 2 points. Required a Steel Ingot.
Ok, I'm a bit more impressed now
Just visited the monks on the top of the mountain, had to run all the way (very tedious), bought a horse which appears to be just as slow as running ... I'm hoping that the dungeons have some difference between them unlike Oblivion
