Obviously not stable seeing as your last post was 40minutes before this one lol
I'm interested in hearing about the longterm users - It seems the more I play with this chip, it needs more vcore to become stable!
For example - last week 4.8Ghz needed 1.32v (fully IBT and prime stable)- This week I'm having to use 1.36v!.
EDIT: Scrap that - forgot about my memory upgrade doh!
Same here prime stable 12 hours 4.6GHz @ 1.290v one week later 1.300v. 4.8GHz 1.340v and now needed 1.365v.
- unlike say for example my 1090T which took nearly 6 months to require a tad more vcore - hmmmmm, maybe I should just settle with 4.8 @ 1.36v, don't want to push it too much tbh.Thanks for confirming mate. It seems these chips degrade pretty quickly. I thought it was my mainboard with instabilities!!
I WAS getting 4.6 @ 1.28v, 4.8 @ 1.32v, and 5Ghz @ 1.41v all fully IBT and prime stable. As the weeks have progressed I can't seem to get 5Ghz stable anymore (without going above 1.45v which I refuse to) and 4.8 requires 1.36v. 4.6 is slightly higher too
I find all chips do degrade slightly when extreme overclocking them, but one week is bloody quick!!- unlike say for example my 1090T which took nearly 6 months to require a tad more vcore - hmmmmm, maybe I should just settle with 4.8 @ 1.36v, don't want to push it too much tbh.
be warned 2700k users!!
ask gibbo if he's having that problem with the maximus iv extreme-z![]()
well mine needs 1.30v for 4.6ghzI WAS getting 4.6 @ 1.28v, 4.8 @ 1.32v, and 5Ghz @ 1.41v all fully IBT and prime stable. As the weeks have progressed I can't seem to get 5Ghz stable anymore (without going above 1.45v which I refuse to) and 4.8 requires 1.36v. 4.6 is slightly higher too
only 6 months?I find all chips do degrade slightly when extreme overclocking them, but one week is bloody quick!!- unlike say for example my 1090T which took nearly 6 months to require a tad more vcore - hmmmmm, maybe I should just settle with 4.8 @ 1.36v, don't want to push it too much tbh.
i don't think it starts degrading until u go over 1.38-1.4v also high temps can degrade it
only 6 months?
my 1090t as been at 4ghz 1.425v for well over a year.
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425-1.450v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
My ram is rated at 1.5 volts, but the MB has set it at 1.6, should it be set to 1.5?!
i don't understand why ocuk changed the guidelines to this
so which is right?
its common sense tbh.Where is the proof by keeping the temps under 70c as apposed to 75 for eg! stopping degrading?
