Cheapest I found was £18 but even then not sure If I want this tripe. Were is the £15 quid key?
Thanksyou need to enable in the options then it is available selection in the normal menu
anyone having any issues playing on the dedicated servers?
when i join it plays fine for the first ~1 min then it lags out, any ideas how to fix?
thanks![]()
Thx guys, I found the russian Steam CD key ones for about £15-£17. do they really work lol?
Yep, perfectly fine here. It was pretty easy to set-up the VPN to my surprise as well.![]()
are they both separated for SP and other for MP
Call of duty modern warfare 3 and Call of duty modern warfare 3 multiplayer
Seems like a yes![]()
I had a problem with the game crashing last night. After a problem with FM12 SI Games told us to verify the game cache/files. I tried that with MW3 and it found two files that were corrupt and re-downloaded them. Game then worked fine after that.Any one had a disk read error whilst playing SP?
I just can get past it.
hey guys, where did you get the keys for so cheap? I really don't want to spend £30+ on this, but want to be sure they work fine!![]()
