There is a lot of bad advice going around on OcUk for watercooling at the moment, From people new to the WC game.
I disagree, a lot of the advice is spot on, especially for simple matters. but some people are just posting stuff that is flat out wrong, only based on opinion and not cold hard facts.
I am glad someone has pointed it out.
our WC section is good, it is a new section on the forum and the people who frequent the section are truly valuable members of the forum with high levels of expertise. Problems only start when people post flat out false information that they have read on places that have questionable sources.
I am not saying that OcUK will ever be the 'Go-To' place for WC advice, there are UK suppliers with more specialist forums and there is the WC section of Xs which is arguably the place where the WC elite post.
but I am doing what i can here to ensure that all advice posted is factual and concise
			from who and what kind of advice lol?
should i avoid this part of the forum then?
not at all, this part of the forum is superb for beginners as a lot of OcUK members have a vast amount of knowledge, just try to pick your advice carefully and use common sense, if someone suggests something that you are unsure about, then research it for yourself instead of taking it as gospel.
either that or ask for confirmation on an opinion from more members or wait until someone you trust comes into the thread
			Rj gives good advice so avoiding the forum is futile
Im not saying im 100% correct all the time, but I tend not to post unless i have direct expertise on the matter
there are a load of myths within watercooling that need to be dispelled. all because someone reads some rubbish on the internet and takes it as gospel.
fact is, I have tested and tested and tested every possible configuration of watercooling that there is, doubtless using a much wider variety of hardware and WC gear than anyone else on this forum. I would only suggest something to someone if someone is catastrophically wrong in a thread and feeding a newcomer bad advice.
