How do you kill morokei ? I have tried everything even lowered the difficulty right down but can barely scratch him. This bit is really spoiling the game for me ...
Edit - Done it due to a nice bug in the game. When he starts attacking run out the room shut the door and then open and attack. He has no idea where you are and just hovers..
Might not work all the time but worked for me, been hours on that bit..
The idea is that you level up a bit more before going up against him. If you can't beat someone on normal in skyrim, then you are too low a level and you are supposed to go away, level then try later. Bugs in the game are not a valid excuse lol
The difficulty slider is not really designed so you can circumvent this but it still helps. As the enemies don’t scale like they did in oblivion the difficulty slider has diminishing returns in Skyrim. For example if you are level 10 and go up against a level 20 boss, taking the difficulty slider to easiest may only make the boss level 15. Whereas in Oblivion if you were level 15, the boss would be level 15 and using the difficulty slider would make them level 10.
In some ways it is better to set the difficulty slider to the harder side as you will get much more from the game. The test is here, if you go into a dungeon at your level and get ganked by 2-3 regular mobs is it a close fight? If it is simply a 2 hit kill easy fight then you need to up the difficulty. You should loose a fair bit of health in a fight and not just stroll through.
Just made myself Dragonplate armour
Going to start working on this tonight, I keep getting side tracked by side quests. I really need to clear my ever expanding quest log before I end up with one that is several pages long.
