Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
I drop ammo like a man possessed. Ribbon short of my first resupply medal I think. Still think the points system for dropped crates is a bit iffy though, I think it should prioritize squad members for your crate and let any other crates supply anyone else until yours is depleted.
Gets me into a bit of trouble sometimes though. Normally hit 3 as soon I'm spawning on a squad mate and often go into a hail of gunfire holding an ammo crate :D
Even when you smash Q, knife them they still don't get it :mad:
i know. in cod its not as bad as there's a dropped weapon around every corner. once you run out on kharg conquest things get a bit hairier.
and its like when important support i just drop ammo every 30 secs or so, regardless if anyone needs it because they will soon enough. that other people don't even drop it when i need it. that's what makes me rage.on bf3 more than anything okay that and the usas.
Me too, I'm ammo delivery man. It always amazes me that after spawning on a squad member I have to chase them halfway across the map like a deranged stalker to deliver the ammo. Oddly the enemy don't seem to run away from me when bearing ammo, they just shoot :(
I only have one medal so far, resupply x3, coming up to my 4th.
While I'm looking forward to the patch I just hope it doesn't break more than it fixes as so often happens :D
On the Support issue, isn't it still true that even if you press Q at the Support player they can't actually hear your Request for ammo? Hope it's gonna be fixed in the patch.
I really hope they don't handicap the IRNV. I need it!
Unfortunate for you then, they're toning it down in this upcoming patch.
Saying you need it is silly - it gives you ridiculous tunnel vision. If you play with it non-stop you won't be able to see anything when you don't use it. Get a holo-scope on so you can see everything around you and still hit accurately ;)
The IRNV was a laugh when I first got it, dropped it fairly shortly afterwards thoughas it gives you such an advantage it's silly.
And they say recon has no decent toys to play with.
Can you cap a flag with the MAV?
(Had vision of a team using nothing but MAVs, swarming all over the map like some alien invasion).
Unfortunately not, but you can carry people upwards for a while ;) :D
Status
