anyone got osx time machine working on one of these?
not cheap, but I have a license from Work for GroupLogic ExtremeZ-IP - Works great!
Has cashback ended on the N36L? Thanks.
A question for those who have upgraded the graphics: I am running the server headless and don't have any way of plugging it into a screen (my tft only has a dvi input). If I add a gfx card with dvi would it default to using it, or would I still need to go into the bios to switch it to use that gfx card?
Did anyone email their rebate form in?
Yes and received my cheque yesterday![]()
AFAIK, they are identical except the faster CPU
Only very early 160gb N36Ls had the 200w power supply
Later 250gb N36Ls had the same 150w power supply as the N40L
It doesn't really matter either way as no ones posted more than 60-70w fully populated with 6 disks
hi guys,
anyone had a chance to test freenas v7 or v8 vs open filer 2.99
what are the performance speeds for transferring ?
and what protocol is recommended cifs/nfs/iscsi?
I know cifs is used for windows share and nfs is for unix* , but what is iscsi i hear its a much more faster protocol that transfers in blocks
ordered my n40l, questions though
not sure if I should use freenas or whs2011
only really want to backup files atm but may want more in the future
what kind of standby is the best, will only really access the drive several times a week and I want it to be as energy saving as possjble , would it just be worth switching it on when I need it only? or can someone suggest somthing more efficent
