Worked fine here.![]()
Yeah OK, it was me. Installed the wrong one, installed for XKI8 instead of XKI4
So... how do you uninstall an .apk?
NM: Didn't realise it would just be under apps
Thanks. I just noticed the font on everything seems "thicker" for lack of a better description. Not sure I like it, having had the other font for the last 5 months
rp2000
ah yeah i forgot the font is different, dw i soon got used to it, if not you can always download a different one
Need a new ROM for mine, CM7 is really unstable for me at the moment, having to force close every other app![]()
well it was fun guys, leaving this thread now hope you get ice cream soon! (not that soon as i will be peeded off i went for the nexus and lost an sd card slot)
Has anyone had a play with overclocks? Just put mine to 1.6Ghz using Siyah Kernal. Not sure if Quadrant scores count for anything anymore, but I was surprised
better to be peed off than to be peed on. I suspect you'll be peed off soon enough.![]()
So that's what it is!
Uninstalled Vodafone app!
No, CWM creates an exact image of your ROM state and you restore it either via CWM app or CWM recovery (hold volume up + home + power until it loads up).
