Can you have more then 1 companion accompany you at the same time?
I had both a dog and Lydia follow me around, one was for a specific quest though, so I dont know if it would work for random companions, why dont you try it and find out.
Seems that you need to be about level25 before back-stabbing becomes possible - can't get near anyone before they hear me, guessing you need to max the first stealth perk and get some stealthy buffs?
Seeing that 30x sneak attack damage...I'm TOTALLY going thief on my second play through![]()
Just a heads up.
Since installing the 2 Gig exe fix I have not experienced the CTD so happy chappy.
Same here
Would highly recommend it if you are getting CTDs all the time.
I dunno. Theres something thats so satisfying about hacking and slashing at your enemy and then a special attack triggers, grabbing the guy and shoving your sword right through his belly and out his back. Then dropping him like the sack of **** he is!![]()
I know the k+m will be better (hotkeys etc), but I really want to be able to sit back and play and not have to be at my desk.
there is a mod out which adjusts the controller text file to allow you to have up to 7 hotkeys on the xbox controller d-pad now. its out on skyrimnexus. imo the controller works better on skyrim.
Hey guys, I've just reached level 10 and I've been really enjoying the game so far. However I want to ask which direction I should be headed in. It's taken me hours upon hours to find some suitable quests where I don't come up against someone that kicks my arse! I've found leveling to be very confusing so far.
