The *NEW* Photoshop speed test thread. This sample image will make your computers cry!
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
This spawns off from the previous thread here because the sample image in that is small and the test is pretty defunct now, we have more powerful systems and need a higher resolution sample image!
Downloads
1: Sample image (46.8 MB) (62.9 MB extracted) (Photo is my own, it is not to be hotlinked anywhere outside of OcUK!)
2: Photoshop Action file (simply double click to open with PS then it will be listed at the bottom of your Actions pane)
^ Action courtesy of http://clubofone.com/speedtest/
Start the stopwatch the moment you click "Continue" on the dialogue that pops up and stop it the moment the STOP!!! dialogue pops up.
:eek::eek:
:eek::eek:
If there are any changes that need to be made please reply back and I'll update but I think it looks good from here!
Please format results like mine below so it's easier to skim through for everyone interested.
*PHOTOSHOP VERSION*
CS5 12.0.4
*CPU*
i5 2500K 4.3GHz
*RAM & PS ALLOCATION*
16GB DDR3 1600MHz
CS5 set to use up to 10.4GB (71%)
*INSTALL DISK*
Corsair Force 3 120GB SSD
*SCRATCH DISK*
*TIME RESULT*
21.92 secs
I found that by increasing the RAM allowance for CS5 (Edit > Settings > Performance) the time taken to process drops dramatically. Allowing 55% of RAM use gave me 29 seconds! The time to invest in RAM is here :p
*PHOTOSHOP VERSION*
CS5.1 12.1 x64
*CPU*
i7 970 at 3.20 GHz, Turbo Boost enabled
varied
*INSTALL DISK*
Intel SDD 80 GB
*SCRATCH DISK*
varied
*TIME RESULT*
25.3 s with 6 GB allocated, VelociRaptor scratch
23.6 s with 7 GB allocated, VelociRaptor scratch
23.5 s with 8 GB allocated, Intel SSD 160 GB scratch
23.3 s with 8 GB allocated, VelociRaptor scratch
Allocating additional RAM provides a small benefit but no significant boost from moving scratch file to SSD, in this particular case. Others might see more of an impact of course so be interesting to see the numbers as they appear in this thread.
Laptop
*PHOTOSHOP VERSION*
CS5 12.0 x64 (OSX Lion)
*CPU*
i7 2.3GHz
16GB DDR3 1333MHz
CS5 set to use up to 90-100%
*INSTALL DISK*
2 x OWC 3G 480GB SSD, RAID 0
*SCRATCH DISK*
As above
*TIME RESULT*
31.6 secs
hmm mine seems a little fast?
*PHOTOSHOP VERSION*
CS5 12.1 x64
*CPU*
i5 2500K 4.33GHz
12GB DDR3 1600MHz
CS5 set to use up to 9946mb (91%)
*INSTALL DISK*
Samsung SSD 60gb
*SCRATCH DISK*
Samsung SSD 60gb
*TIME RESULT*
21.5 seconds exactly from my iphone's stopclock
OOOOF. CS3 didnt like that one bit, i guess the cruddy max memory usage held my results back...
*PHOTOSHOP VERSION*
CS3 10.0.1
*CPU*
i7 2600K 4.4GHz
16GB DDR3 1600MHz
CS3 usage maxes out at 3255mb
*INSTALL DISK*
OCZ Vertex 60Gb SSD
*SCRATCH DISK*
As above
*TIME RESULT*
3 mins 30 secs
nice kitteh by the way :D
Interesting! Initial thoughts on this test being RAM bound seem quite clear cut given similar specs in CPUs used!
neil_g, is your CS3 not 64bit?
Ready for a laugh? :p
*PHOTOSHOP VERSION*
CS5 12.1
*CPU*
T7500 @ 2.2GHz
2GB DDR2
CS5 set to use up to 1572MB(60%)
*INSTALL DISK*
7200RPM 200GB SATA
*SCRATCH DISK*
7200RPM 200GB SATA
*TIME RESULT*
697 secs
And no, I haven't missed a decimal point... 11 minutes 37 seconds! Time to beat I think! :D
Give me a couple of weeks and I'm certain I'll come back with a slightly better score...;)
*PHOTOSHOP VERSION*
CS5 12.0.4 x64
*CPU*
i7 960 @ 3.4 GHz
6GB DDR3 (triple channel) 1600MHz
CS5 set to use up to 4244MB (80%)
*INSTALL DISK*
Seagate 1TB SATA
*SCRATCH DISK*
As above
*TIME RESULT*
1 minute 16 seconds
Just shows I "need" to get a new personal laptop, or at least desktop (my home desktop would probably produce a score worse than the laptop)...:D
Ouch!
16GB Kingston HyperX 1600MHz kit was going for £50 last week at a competitor, absolute bargain!
having just bought a 5d2 , 24-70 and a 5dc this spec will have to keep me going for a while
*PHOTOSHOP VERSION*
CS5 12.0.4 x64
*CPU*
e6600 2.4GHz
8GB DDR2 800MHz
CS5 set to use up to 6470mb (90%)
*INSTALL DISK*
2x WD raptor 74Gb (raid0)
*SCRATCH DISK*
WD Caviar Green 2 TB SATA
*TIME RESULT*
191 secs
*PHOTOSHOP VERSION*
CS5 12.1 x64
*CPU*
i5 2500K 4.33GHz
12GB DDR3 1600MHz
*INSTALL DISK*
Samsung SSD 60gb
*SCRATCH DISK*
Samsung SSD 60gb
*TIME RESULT*
Yeah, are you sure you did it right? Did you get the 'stop the clock' message pop up at the end and something about visiting a website?
Not sure i did it right either as took around 30 secs when i did it yesterday (i7, 6GB DDR3) and i didn't get that message pop up. I've just done it again today and it's taken around 78 secs...
*PHOTOSHOP VERSION*
CS5 12. x64
*CPU*
2 x 2.66ghz c2d Xeons
9GB 667mhz DDR2
CS5 set to use up to 100%
*INSTALL DISK*
Western Digital 1TB 'Green' drive
*SCRATCH DISK*
Same as above
*TIME RESULT*
2.16
Hmmm...machine is showing it's age now :p
I'd love to see some more Mac results. :)
Here's my 3 year old PC
*PHOTOSHOP VERSION*
CS5 12.0.4
*CPU*
Q6600 3.55GHz
4GB DDR2 1066MHz
CS5 set to use up to 2064MB (60%)
*INSTALL DISK*
WDC WD1600AAJS-08WAA0
*SCRATCH DISK*
*TIME RESULT*
124.3 secs
:o
This is for my 2008 Mac Pro, model 3,1:
*PHOTOSHOP VERSION*
CS5 12.0.1 x64
*CPU*
2 x 2.8 Ghz Quad-Core Intel Xeon
12GB DDR2 800MHz
CS5 set to use up to 11478mb (100%)
*INSTALL DISK*
Hitachi Deskstar 7200rpm
*SCRATCH DISK*
2 x Hitachi Deskstar 7200rpm in RAID 0
*TIME RESULT*
61 secs
I found changing the RAM slider in Photoshop had little difference from 75%.
Interesting! That sort of indicates the memory managers vary between OS which in itself is not that interesting but it does tell you that Widnows 7 hands apps better when they're allowed to use more RAM!
Or is that Adobe's coding of PS...
