Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Not true
Front Side Back
1 RPG 22 36 61
2 Tank Cannon 24 34 58
3 TOW Missile 34 49 81
4 Transport Chopper Minigun ? 61 96
5 Attack Chopper Gun 61 87 100
6 Attack Chopper Rocket 43 43 43 Armor does not affect damage
7 Javelin 35 35 35 Armor does not affect damage
8 C4 50 50 50 Armor does not affect damage
9 AT Mine 50 50 50 Armor does not affect damage
10 Mortar 22 22 22 Also has splash damage
11 Jet Rocket 43 43 43 Armor does not affect damage
12 Jet Machine Gun 22 ? 89
13 Engineer Torch 4.5/sec ? 12.5/sec
14 Grenade 0 0 0
15 Anti-Air Cannon 39 61 100
nice one :)
Anyone else think that nades should hurt vehicles? Being a medic and coming up against any vehicle is a pain in the ass.
Maybe that suppression / concussion effect for those inside, or 10% off a Humvee, but nothing dramatic. I know what you mean, though - I've been trying to play as squad medic recently, and there's nowt worse than not being able to do anything about a poxy Hummer :D
I say "trying", because the team-play is so varied. Being in a decent squad is make-or-break for whether I have a good game - not score-wise, though it helps :) I mean I can't bear it when you get dumped in a squad and one loner's camping out in the hills, someone's in a jet, and the last one is driving past in a tank, not bothering to pick you up as gunner :mad:
:p
http://shop.x22cheats.com/showthread.php?t=30317
Pretty bad that people are just fine to use hacks. Most bizarrely, they clearly like the games, but feel the need to cheat.. most odd :rolleyes:
Surely it can't be that hard for PB to take this software and detect it/screen shot it?
It isn't, but these companies release updates most days. These people get paid to make these hacks, so it's a job to them :)
Hey guys,
Just got my new computer up and running and downloading BF3 as we speak! Just wondered, without searching throughout the whole thread - what seems to be people's preferences in Mumble Servers (which is move active) and which servers will I see some Overclocker's guys on?
Also, if anyone wants to add me for some games, no doubt I'll be on till the late hours, then please do add me! :)
The ocuk mumble server is active most guys on there are usually on Smogsys server the Killer creation broken gaming server is active as well.
Here is the link for the mumble details: http://forums.overclockers.co.uk/showthread.php?t=18281232&highlight=mumble
Are there no unlocks for assault atall that can deal with a vehicle then? thats pants.
Good to know the nades can do something to them, I just find it annoying that I can roll one right under the tank/hummer and it does nothing :P
Best thing you can do as an assault is to launch smoke grenades not only it acts as cover, but if you launch them at the tank your team mates can run and C4 it :) I'm not sure how much damage the grenade does thow
Grenades shouldn't do anything.. they are anti-infantry devices, designed to kill via shrapnel and the concussive effect. They are not designed blow holes in things. (Which is different to an RPG as far as I'm aware).
Quick Q. A friend has an Athlon64 x2 5600 and a 8800GTX, he's thinking about buying a new graphics card to play this. Will the 5600 be ok at stock (2.9 iirc) or will there be a major bottleneck if he bought, say a 560GTX Ti
I had an e7200 @ 3.1Ghz and an 8800gts 512 and could play it fine all on low. I upgraded to an ATI 6850 and found the FPS wasn't really changing whether I had it on low or high, which obviously indicated it was CPU bottlenecked. I've since then upped my OC to 3.3, and it runs much better now. I can have it on all high, no AA, and get around 45fps on all maps. Still get a bit of stutter every now and then on 64 player maps, but I'm going to put another 4gb of RAM and see if that helps.
In short, yes he'll probably be bottlenecked, but a bit of overclocking should help.
i asked before but does anyone know if i can use my xbox headset on my pc?
is it just a case of plug it in and away i go or do i need a specfic mic?
I dont know im afraid, I have the 360 controller with a USB attachment and its plug and play...best way is to give it a try :D
Status
