- 2 Feb 2010
- Crowmarsh
Talk about the mother of all botched launches!
just calm down - wait and see what samsung/google will say in the next 48 hours.
Hmm.. computer runs on Linux so I need to connect the phone via the "camera" mode. Only shows around 1gb available - so I can't transfer all my music! Is that expected when connecting in camera mode? No windows PCs nearby to compare...
While I agree nobody should do anything too rashly at this moment in time, I can't see how this is going to have a good outcome given the video evidence we've seen so far.![]()
i don't have the problem, running a voda sim in a o2 handset, but if i did i would be calling the shop and making sure there is a suitable outcome if this cant be fixed. i doubt you will be left high and dry, maybe a recall and replace, or hopefully some sort of fix
You probably do, you just aren't on a 900Mhz band.
i have no idea what that means.
to be fair i have not really been anywhere since i had the phone, does it change within certain areas?
There are multiple reports of an automatic volume-changing problem by Galaxy Nexus owners. In order to rate the scale of the problem I'm putting up a post so we could have a better idea about how many handsets are affected.
All signs point to hardware problem that might lead to mass-recall by Samsung. Everybody has tried to contact Samsung ever since the release, but there's been no definite comment by them nor even a confirmation that they are looking into it. Samsung UK Facebook wall has multiple posts by users, none responded to by Samsung: https://www.facebook.com/SamsungUK?sk=wall
This is what we know so far:
- What happens is that the phones volume will go haywire, it will start lowering volume hectically on the phone, especially during phone calls or when radio is being switched from 3G to 2G, or data connection is activated while WiFi radio is turned off or on.
- This only happens when the phone is on 2G connection (that is, when phone shows G (for GPRS) or E (for Edge) icons for connection).
- It only happens to phones that use 900Mhz for 2G coverage, which is majority of Europe. Confirmed networks in UK since launch are O2, Vodafone, giffgaff, Tesco Mobile. But note that majority of Europe uses 900Mhz (GSM 900) for 2G coverage, so if you live in Europe, there's a large change you would be affected.
- Problem becomes even worse when phone is in a low signal area. By transmitting more to hold onto the signal, the problem becomes more frequent. It often temporarily locks the use of the phone due to 'ghost volume button' being spammed.
- This problem holds back the phone from used properly, at all, in majority of conditions when on 2G network. Calls are dropped, alerts diminish and so on.
- Currently it affects apparently more than 60% of handset owners in UK. It is possible that this problem exists on every phone, other users simply are not on aforementioned networks or do not use 2G.
This issue even happens if Nexus is not used at all and has all radios turned off. If another device that uses 2G (GSM 900 network) is nearby, the Nexus volume will drop. As predicted, this is a radio interference that Nexus is unable to handle properly. Here are videos that show exactly that: http://www.youtube.com/watch?v=BIFRYY25fDo and http://www.youtube.com/watch?feature=player_embedded&v=qXjARxvErjk
This problem also happens during bootloader, so it is not a flaw of Android 4.0
Just high demand. I'm just going to go and crawl under a rock for a few days, getting really disappointed with this now, I can only maintain this level of excitement for a new product for a few days, now I'm just reserved to the fact that it will take forever.
really is no point worrying just yet, just need a statement from samsung and or google.
Hadn't noticed until I held a blackberry to it and it spazed out. Which frequencies does 3 use?
A product recall with hit them hard (much like the phone signal thing with the iPhone 4), it'll be interesting to see how they handle it though.
